I basically copied Elephant Racing's install method but used a pipe clamp instead.
So no need to put a hole in the end of the control arm, and no need to clamp the a-arm to a bench or put it in a vice to hold it steady - I kept everything aligned by holding the control arm and pipe below it with one hand and tightened the clamp with my other hand, and the bushings easily slid straight on.
Only tools used were the pipe clamp (cast iron pipe and Bessey clamp available at Lowes/Home Depot for $25ish), 914 rubber's install tool (included with my bushings), and dish soap.
[/url]
