QUOTE(Superhawk996 @ Sep 29 2022, 11:42 AM)
QUOTE(Sea Rooster @ Sep 29 2022, 12:41 PM)
So what exactly is the purpose of this part? What does it vent and is it necessary?
Ventilation systems always need a vent when glass is up and roof is on. Otherwise you end up trying to pressurize a box. Once the box is pressurized actual airflow will stagnate.
Yes the 70s vintage door seals and window seals are pretty leaky vs modern seals but none the less, cabin would quickly pressurize and stagnate making the defrost and heating system way less effective if not vented.
And if you have good seals that are adjusted and tight, closing a door with the windows up and top on without vents to relieve the pressure would not be a good thing. Even with 70s style seals, my car is tight enough you can feel the pressure bubble when a door is shut.
