QUOTE(bbrock @ Oct 2 2022, 08:47 AM)
Very impressive. What kind of engine work has been done in those miles? Just curious.
I did an autopsy on the engine around 325 K, cam worn out, lifters scored, I posted a photo of the heads and Len pointed out that a valve guide was replaced and the heads were in bad shape. 1972 1.7 so I could just make improvements from here.
Click to view attachment So I did, AMC heads done up as 2.0L 3 stud, Nickie cylinders, J&E forged pistons, 9550 cam, I used Jakes pushrod procedure, cutting them using an arrow saw. Set the compression ratio at 8.4:1 and I updated to a 1974 version of D-Jet. In the last year I’ve been tuning the 123bluetooth dizzy to run regular gas, with success.
95mm pistons, 71mm stroke.
The body was a very different story, seen in this post:
http://www.914world.com/bbs2/index.php?sho...=211943&hl=I asked that in 2012, I listened to one individual whose advice was spot on.
What I did was spend about 3 years in body shop classes.
My first teacher, Mr. G had just restored a 21 window bus, he taught me how to section, how to remove with the least amount of damage and how to restore.
Click to view attachment My second teacher Mr. Solise took a piece of sheet metal, bent it over his knee and created the lower fender section of a 1950’s chevy pickup, I was hooked, I learned how to use an English wheel, a plastic mallet and a shot bag.
But what I did years ago finally mattered. On a whim I took welding classes at El Camino College, I became proficient in welding 2 inch steel using submerged gas, and aluminum cans together using tig. I took 2 years to do that, I became a member of Arne’s army, a great welding teacher Arne Arneson (that was 30 years ago, I may have spelled the name wrong.)
One thing he taught me was, when you feel comfortable, take yourself out of that zone and challenge yourself. That pushed me to do the out of position welding from under the car. I’ve watched hundreds of welds gel and solidify 6 inches from my face (oh my beard is halfway to my navel and my hair is halfway down my back) I’ve been lucky, so far.
Click to view attachmentI call this nose job on a laughing robot.
Welding, sanding filler and painting are quite cathartic for me
Before
Click to view attachment After
Click to view attachment And here I thought someone would say, hey in German that reads no no 914.
