Thorshammer
Aug 7 2005, 03:35 PM
Putting together a FP race motor for a friend, Need the torque spec for the case through bolts and the raceware head studs. Jake You around???
Do you think much of these or not???
Thanks,
Erik Madsen
Al Meredith
Aug 7 2005, 06:56 PM
Eric, I hope Jake answers this thread. He showed me how the center bearing is always shiney (moving around). He suggested taking a little off the split bearing by using valve grinding compound on plate glass. Like I use on a T 1 oil pump cover. From this I would say the Raceware hardware is a good thing at high RPM. BTW Blake was turning over 7500RPM on his E production 1800CC T4 and never had an issue with mains. We did use Raceware hdw! Al
Powerman
Aug 7 2005, 07:14 PM
http://www.arp-bolts.com/pages/tech/images...es/fasttorq.pdfI have these on my motor, but I can't find where I wrote it down.
I bought them from L&N Engineering, I believe I called Charles.
They spec torque with the little tube of ARP anti-sieze. I'll look somemore.
I think I have oil on the ARP bolts in the Crower rods.
