QUOTE(dumbjim @ Oct 3 2022, 04:59 PM)
Hi group, I recently replaced my accelerator cable and I'm not able to get in my main carb circuit. I have dual webers with tangerine cable linkage and I'm not able to get out of the idle circuit. There is no slack in the cable and I'm out of ideas. Any help would be muchly appreciated.
Have you checked it's not wrapped around the clutch cable in the tunnel? It's the most common problem when changing the throttle cable. If you have one, use an endoscope attachment on your iPhone to look in the tunnel from the front.
