neo914-6
Aug 7 2005, 04:33 PM
I have a 50k JPEG as listed in Explorer. When I open it in Adobe PhotoDeluxe BE to resize , it lists 1.09 Meg and a 400" width!
When I resize it to 11" width it is only blurred pixels. I posted it on a test and it posts fine.
I want to print it but in it's present format it overloads my laser printer memory. How can I resize it to print?
Demick
Aug 7 2005, 04:42 PM
it's only 1 pixel per inch. That's only 400x400 pixels. That's already low resolution. Only reason to resize that is to make an avitar or something.
neo914-6
Aug 7 2005, 04:56 PM
At 400" it won't print.
What is the relationship of paper size to pixel size?
seanery
Aug 7 2005, 04:58 PM
usually print is 300dpi - 1200dpi...your image shows settings of 1dpi...so every pixel will be 1 inch in size
seanery
Aug 7 2005, 05:00 PM
let's say you want it to fit on an 8x10...resize it to:
2400x2400 @300dpi...that will print it 8"x8" but it will break up a bit because it's 6x it's current size. you can do the math to figure another size, but remember You need to change the resolution from 1dpi to approx 300dpi.
neo914-6
Aug 7 2005, 05:48 PM
QUOTE (seanery @ Aug 7 2005, 03:00 PM) |
2400x2400 @300dpi...that will print it 8"x8" but it will break up a bit because it's 6x it's current size. you can do the math to figure another size, but remember You need to change the resolution from 1dpi to approx 300dpi. |
all my program seems to allow is to change the size, not the resolution.
seanery
Aug 7 2005, 06:17 PM
post it here and I'll fix it. Tell me what size you want it to be.
neo914-6
Aug 7 2005, 06:24 PM
here you go...
I need letter size 8 1/2 x 11 or slightly smaller
seanery
Aug 7 2005, 06:57 PM
neo914-6
Aug 7 2005, 07:03 PM
Thanks Sean,
Do I need a different program to do this?
seanery
Aug 7 2005, 07:05 PM
try photoshop elements, it should do it, and I think it's a gimme or damn near it price-wise.
