speed metal army
Oct 10 2022, 04:55 PM
Some advice on exactly where the mounts go in a late car, and a vendor for the mounts would be great.
Pics please of the mounts welded in!
Thanks
Mikey914
Oct 10 2022, 05:19 PM
https://914ltd.com/product/porsche-914-orig...way-bar-mounts/Brad Mayer makes a high quality product. These are not a thin gauge metal
We stock his stuff too. Unfortunately, will not be around my car until tomorrow evening.
speed metal army
Oct 10 2022, 05:43 PM
Arent those are the early bar ones Mark ?
I’m looking for pictures of a late car with the bars installed.
914Sixer
Oct 10 2022, 05:55 PM
Yes that is early not 75-76. Just pop the body plugs and weld them in.
speed metal army
Oct 10 2022, 06:10 PM
QUOTE(914Sixer @ Oct 10 2022, 04:55 PM)
Elaborate please. With pics if possible!
Mikey914
Oct 10 2022, 06:11 PM
I'll check my 75. Thought Carry used these on mine.
speed metal army
Oct 10 2022, 06:19 PM
QUOTE(Mikey914 @ Oct 10 2022, 05:11 PM)
Text me a pic Mark
Mikey914
Oct 10 2022, 08:12 PM
Will do tomorrow.
-Mark
sixnotfour
Oct 10 2022, 08:13 PM
Mikey914
Oct 10 2022, 08:32 PM
Thanks for posting that up. The picture is wrong I'll get that corrected. It should be exactly the same as Brad has pictured.
914werke
Oct 11 2022, 10:37 AM
Before you change anything Mark, the comments or corrections are correct.
The early brackets (70-74) are the ones you posted above.
Due to the change in the chassis to accommodate the bumper shock setup on the late 75-76 cars those brackets changed to the simpler version (on your page sixnotfour posted).
The installation is the same for both. The leading weld nut is located into the factory hole (may have a plastic cap/plug inserted) and is oriented length-wise to the back of the car & welded.
friethmiller
Oct 11 2022, 01:34 PM
Interesting, I'm about to fab/weld in a new set of tabs into my trunk for my factory sway bar. Anyone have any info on the thickness? 16 gauge?
Chris914n6
Oct 11 2022, 02:00 PM
Here are the ones I made for my 75. Not complicated = make your own.
speed metal army
Oct 11 2022, 02:26 PM
QUOTE(Chris914n6 @ Oct 11 2022, 01:00 PM)
I plan on it. How about a photo of where they go??
Front yard mechanic
Oct 11 2022, 03:40 PM
My 1976 original mounts
speed metal army
Oct 11 2022, 04:00 PM
QUOTE(Front yard mechanic @ Oct 11 2022, 02:40 PM)
Click to view attachmentBoom!!
Thanks!!
Front yard mechanic
Oct 11 2022, 04:21 PM
QUOTE(friethmiller @ Oct 11 2022, 11:34 AM)
Click to view attachmentLooks like 1/8” to me
76-914
Oct 11 2022, 04:33 PM
Just be sure to weld the 1/8" plate to the trunk floor.
Click to view attachmentOr come back later to weld up the tears in the trunk floor.
Click to view attachmentClick to view attachment
