So the engine is out..
I am attaching photos.
The leak is coming from the front of the motor. It appears my main seal # 8 bearing is dry, but under it is wet. But it is wet above the Intermediate shaft cover. Fan blowing it all around and coming from there? Thoughts?
Thank you.
Click to view attachmentClick to view attachmentClick to view attachment
___________________________________
Hi there,
A question for the esteemed who know more than I do!
I am tackling oil leaks on my 2.7 six conversion. Today I changed out the driver side axle flange seal which was leak #1.
Tomorrow or Wednesday I will tackle the Oil return tube seals. (Thank you Bruce for the nice set of spare tubes I will be using).
Leak # 3 is likely my front main seal, behind the pulley. I am hoping it is not a leaky #8 bearing and is just the seal, but the oil is coming from that area and I won't know more till I get it apart.
The question is: Can it be done with the engine mounted, and not require a drop? I have a non factory mount, likely the Mad Dog style mount that pivots.
I know it is "easier" if the motor is out, but that is a whole other adventure...
Thank you all.
Robert
