QUOTE(NARP74 @ Oct 12 2022, 05:01 PM)
The PET is not very descriptive on all hardware, and this is one of those situations. It just says sealing washer and washer. 999 part numbers, is that custom or off the shelf?
999 parts are usually off the shelf, but not part of the DIN spec. Since the tapping screws are 4.8mm, we can guess that the inner diameter of the washers are the same as M5 — but what is the outside diameter? Since it’s a 999 part, we can assume it’s different from a regular M5 washer. Someone installed several different sizes on mine, and I’m just trying to figure out what the ‘correct’ size is/are.
Hoping someone can help answer these specific questions:
1) Do both the ‘washer’ and the ‘sealing washer’ have the same OD?
2) Is the ‘sealing washer’ simply a rubber washer?
3) Is the ‘washer’ a plain flat washer?
