QUOTE(Highland @ Oct 13 2022, 02:19 PM)
QUOTE(SirAndy @ Oct 13 2022, 10:17 AM)
QUOTE(VaccaRabite @ Oct 13 2022, 06:08 AM)
I've never removed the axles to remove or install an engine. Just put plastic bags on the CVs to keep grease contained.
Just unbolt the CV's on the transmission side and slide the whole thing out the back. No need to remove the stub axles and risk ruining the wheel bearings.
Is it possible to reinstall the axle if removed with the above method or does the stub axle have to be removed to reassemble the CV?
You don't remove the axle. So there is no need to do anything with the stub axle.
You are literally pulling the 4 bolt off the CV that attaches to the transmssion, and putting a bag around the CV, and that's it. The axles just kinda hang down and you push them around as needed when removing or installing the engine. You do not take apart the CV, remove the stubs, or any of that. In fact, you don't even touch the outer CVs.
On reinstall, you put in a new seal, use new bolts and new washers.
Zach
