Mowog4
Oct 24 2022, 04:51 AM
I am looking for suggestions on how to vent a tank with an in-tank pump. Fuel smell, and fuel sloshing are an issue. Any suggestions
GregAmy
Oct 24 2022, 06:42 AM
Can you describe your goals? I do this in my 914 racer with a fuel cell.
tygaboy
Oct 24 2022, 06:56 AM
I'm running a Aeromotive Phantom in-tank pump in my LS car and I get a bit of fuel smell, too. I'm still developing the car and it runs an "open" vent line so I plan to route it to a charcoal filter. Maybe I'll reposition a stock one or give a go t making a custom one I can hide.
Van B
Oct 24 2022, 07:12 AM
You need a charcoal canister for fuel smell. That is still the go to solution. For sloshing you need either fuel tank foam or internal baffles.
Mowog4
Oct 24 2022, 01:26 PM
I will add a charcoal canister, the sloshing is fuel running out of the vent tube when it is full. I’ll have to come up with a way to vent the tank higher in the air.
Mowog4
Oct 24 2022, 01:50 PM
I will try to modify an expansion tank to work, see if that works
FL000
Oct 24 2022, 07:47 PM
This is my setup. Evap canister didn’t fit but vent goes to charcoal canister then back to air intake.
Fuel slosh smell is still an issue but only when filled to the brim and on the turns.
Mowog4
Oct 24 2022, 09:10 PM
QUOTE(FL000 @ Oct 24 2022, 06:47 PM)
Click to view attachmentThat looks great, very clean. I’ll need not to fill to the top.
falcor75
Oct 24 2022, 11:06 PM
There are two way springloaded vents that only vent when there is an inside/outside pressure difference.
Click to view attachmentI am using this for my seven replica and I have zero issues with fuel smell in the garage.
Mowog4
Oct 25 2022, 08:08 AM
QUOTE(falcor75 @ Oct 24 2022, 10:06 PM)
Interesting, where did you source it?
andys
Oct 25 2022, 11:39 AM
QUOTE(Mowog4 @ Oct 24 2022, 08:10 PM)
I did a FiTech pump, stock expansion tank, and charcoal cannister. No fuel smell or slosh.
Andys
Mowog4
Oct 25 2022, 04:41 PM
QUOTE(andys @ Oct 25 2022, 10:39 AM)
Andys
Click to view attachmentAndy
Looks great, any more pictures?
Thanks Ed
falcor75
Oct 26 2022, 12:55 AM
QUOTE(Mowog4 @ Oct 25 2022, 04:08 PM)
I bought it locally here in Sweden in a store that specialises in industrial parts (llike McMaster-Carr) but you could make one yourself from a threaded plug, set screws, springs and ball bearings.
Here is a parts link.
https://www.wiberger.se/produkt/m_tsvv
