QUOTE(torakki @ Oct 28 2022, 04:31 PM)
OK. Clay, you're on to something. First, I checked the switch on the hand brake. No difference, in or out. Then, jacked up the car and pushed in the little plunger (maybe 1/8"). A little hard to push in and stayed in. Light still flashing but when I release the hand brake, it goes off now.
That's how it is supposed to work.
Lockwodo - I recently bleed all the brakes and slowly getting a good pedal. I will continue to bleed since the hand brake wont stop the car from rolling. I think there's a stuck piston or two.
Did you check the venting clearance on the rear calipers? It has to be set correctly or the park brake won't work. The procedure is in the Haynes manual. But be aware, the clearance they specify in there is wrong. It should be .004 not .008.
Hope that helps.
Clay
