Any 2056 owners using stock FI?
What spark plugs are you using?
Update to this post:
Two of the spark plug holes(one on each side of the engine) in my new cylinder heads don't line up with the engine tin holes. I am not able to get the spark plug socket on the spark plug unless the spark plug is already installed. I am also not able to remove the spark plug all the way out without jamming the socket against the tin.
Option 1: make the freshly powder coated engine tin holes larger to accommodate the stock NGK 13/16" hex spark plugs. These have a 1mm protrusion.
Option 2: use NGK 5/8" hex spark plugs. These have a 3mm protrusion. Will this be an issue?
Other options?
Thanks
Click to view attachment Click to view attachmentClick to view attachment
