So I bought this Bumblebee on BAT that was extensively restored around 2000 and has seen little use since. My plan is to drive it, including to Rennsport in 2023 and other 914 events in the future like Octeenerfest.
So the car runs and drives and is in overall excellent condition. It does "hunt" at idle and has a slight miss under acceleration. However, 20+ years of sitting and having original plastic fuel lines has me planning a winter "refresh" geared toward proactively making the car as reliable as possible. Still running the Djet FI which I want to keep.
Please add to my list to help with projects I will do over the winter. I will drop the engine as part of this process.
Here is what I have so far:
SS fuel line kit from Tangerine Racing
New rubber fuel lines
New vacuum lines
New fuel filter
Take fuel injectors to Mr. Injector for testing - he is local to me
Inspect fuel tank, replace tank screen
Replace TPS board
New spark plugs and ignition wires
Install 123ignition distributor
Valve adjustment
New fan belt
Oil and trans fluid change
Send fuel injection harness to Jeff Bowlsby for inspection
Brakes seem good, will flush and replace soft brake lines
Seat belts re webbed
Inspect shifter bushings, replace as necessary
Install turbo tie rod kit
Install engine firewall pad - was left out of restoration
Clock is inop, send to get converted to quartz
Replace clutch and throttle cables, keep current for spares
Inspect clutch components with engine/trans out
Inspect wheel bearings - repack/replace as necessary
New tires, set ride height (front is a bit proud to my eye) and align
Inspect all suspension bushings
Replace side graphic with new from 914Rubber
What am I missing?
