bkrantz
Oct 30 2022, 09:25 PM
ALL THE STUFF IS SPOKEN FOR!
OK, here are my lists of parts I think are worth something (for sale) and not so much (free). In all cases, you pay shipping or arrange some other hand-over (I can bring things to Tucson in November, and probably get things to Denver by end of the year). If you want more info, send my a PM.
And the most important rule: first reply here (not PM) gets the part.
Stuff For Sale:
2.0 Cylinder Heads rebuilt $600
2.0 fuel injection brain box used $100
Fuel Injectors (Intermotor FJ67) (4) new $200
Dual carb throttle linkage kit (air filter bases only, one base has notch) new $100
2.0 throttle body used $100
Bosch blue coil 0-221-119-309 used $25
distributor 0-231-174-009 (VW 039-905-205) used $100
manifold pressure sensor and bracket used $150
alternator rubber air duct new $10
alternator rubber wire connector cap new $3
2.0 air filter housing and bracklets (powder-coated) pc $150
2.0 intake plenum (powder-coated) pc $80
heat duct flapper valves L and R used $60
911 speedometer angle drive like new $25
transaxle ground strap new $20
brake master cylinder, 914 Rubber, 19mm like new $50
fuel filter, WIX 33274 new $5
fuel filter, WIX 33033 new $4
fuel line grommets, 8mm (2) new $5
fuel pump rubber mounts (2) URO new $30
headliner new $20
windshield butyl cord new $10
windshield trim clip kit (19 clips plus 2 rubber shims) new $20
trunk plastic clip for targa top (1) like new $4
headlamp surrounds L and R used $40
window winders (2) used $50
door switch rubber boot (4) new $15
door switch (2) new $15
triangle window rubber L and R new $50
LE style front spoiler, fiberglass used $100
enigine lid rain drain kit (hoses, clamps, and funnels) new/used $25
door card plastic pins, white URO (10) new $20
door card plastic cups (20) new $20
vent control triple-cable rubber grommet new $10
foam speaker baffles, 4x6 (2) new $5
aluminum inner and outer door sills (2 each) used $40
fuel pump, 3-way used $75
Stuff for Free (all used):
2.0 Pistons and Cylinders
2.0 intake runners
2.0 rocker shafts and springs
push rod tubes
cam, gear, and follower set (not stock)
oil cooler
injector pipes L and R
intake plenum sensors, springs, and fittings
fuel pressure valve (2)
cylinder head temp sensor
alternator wire harness
non-Porsche starter relay
pushbutton switch
wheel center caps (4), rough
blower fan single outlet
front turn signal light lens (2)
door vinyl L and R, black
non-Porsche interior rear view mirror
L door window channels, winder, interior latch and rod
fog lights (no gaskets or bases) (2)
fog light grills L and R (painted black)
non-OEM shift knob
seat belt indicator light
trunk lid latch pin
door handle (sanded surface)
brake master cylinder, ATE 19mm
2.0 muffler hanger
2,0 injection wire harness (rough)
targa side trim L and R (aluminum finish)
targa side trim L and R (painted black)
targa top trim (painted black)
left tail light housing (rough) and lens (OK)
engine lid rain tray
dash top, one big crack
door card plastic pins (13) original
L door inner latch mechanism
saigon71
Oct 31 2022, 05:41 AM
I'd like the following free parts please:
2.0 Intake Runners
2.0 Rocker Shafts & Springs
Intake plenum sensors, springs & fittings
Fuel prressure valve (2)
Front turn signal lenses
Fog lights
Door handle (sanded)
2.0 injector wiring harness
Alternator wiring harness
Shipping to 17019
Thank you!!!
cassmcentee
I'll take the complete package! (minus what I missed out on the "First Dibs")
Will make a great road trip for me this December if you can wait till then?
(I just started cutting out the Floor Pans on my project, need to gather future parts)
sjhenry1075
Oct 31 2022, 06:15 AM
Can you send me pics of the heads? I'm definitely interested in them.
Nate W
Oct 31 2022, 07:20 AM
PMed on the triangle rubber, door sills, windshield butyl and clips, and headliner
Thanks
aharder
Oct 31 2022, 08:07 AM
Ill take to 2 door switches and the 4 door switches seals.
shipping to 75228.
Thanks.
friethmiller
Oct 31 2022, 08:22 AM
I'll take:
2.0 air filter housing and brackets
Fuel injectors
bosch blue coil
Ship to 78726
Thanks,
Fred
pedrok
Oct 31 2022, 09:12 AM
Hi I'll take
Stuff free:
Fog lights 2
2.0 hanger
push rod tubes
If they still usable: 2.0 Pistons and Cylinders
Ship to 91950
Thanks
Pedro
frostyf
Oct 31 2022, 09:18 AM
Is the targa side trim pieces, shipping to 23455. If there are any of the door switch rubbers left I'd be keen to get two?
Thanks Nick
GeorgeKopf
Oct 31 2022, 05:11 PM
I would like:
engine lid rain drain kit (hoses, clamps, and funnels) new/used $25
Shipping to 08540 please.
I will send you a PM as well.
Thanks.
George
bkrantz
Oct 31 2022, 08:21 PM
QUOTE(saigon71 @ Oct 31 2022, 05:41 AM)
2.0 Intake Runners
Fog lights
Shipping to 17019
Thank you!!!
I will weight these and send you a shipping cost.
bkrantz
QUOTE(cassmcentee @ Oct 31 2022, 05:41 AM)
Do you mean the rest of the free parts or everything?
cassmcentee
Oct 31 2022, 08:25 PM
QUOTE(bkrantz @ Oct 31 2022, 09:21 PM)
I figured everything... What I end up not needing will end up here again, same offer when it happens
bkrantz
Oct 31 2022, 08:43 PM
Cylinder head photos.
bkrantz
Oct 31 2022, 08:46 PM
QUOTE(cassmcentee @ Oct 31 2022, 08:25 PM)
OK, switching to PM.
scottsilvertt
Oct 31 2022, 09:22 PM
I might be too late,
But I would be interested in a cpu, brain box if it’s for a 1974.
# Ending in 043.
And the windshield butyl snake.
saigon71
Nov 1 2022, 02:06 PM
QUOTE(bkrantz @ Oct 31 2022, 10:21 PM)
2.0 Intake Runners
Fog lights
Shipping to 17019
Thank you!!!
Excellent! Thank you.
bkrantz
Nov 1 2022, 08:23 PM
I think we are done. According to the rules, saigon71 gets several parts, and cassmcentee gets the rest. If one of these guys changes his mind, I will relist parts. Thanks, everyone.
Sea Rooster
Nov 2 2022, 06:18 PM
I'll take the 73 2.0 Throttle body. PM sent!
