[quote name='bdstone914' date='Nov 5 2022, 03:22 PM' post='3039766']
They both move but one can not make the turn inside the tube and is stuck
[/quote]
Carefully reduce the bend of the tube. You can use a Phillips screwdriver in the end of the tube to reduce the radius by a few degrees
[/quote]
@obscurity I think Mark is right. I had to do this recently to remove a cable. Look for any kink in the tube. Straighten slightly.
If it is stuck and you cant move it, cut the tube off ahead of the bend and replace it later.
[/quote]
I couldn’t get a new one in one of my cars. Reducing the radius by just a degree or two let it slide in easily.
