Driver174
Nov 12 2022, 01:33 PM
I have the desirable W case and want to prepare it for a future build. Is there a procedure or instructions written somewhere explaining how to prepare a case assembly?
I wouldn’t mind purchasing this information; maybe Mr. Raby offered something in the past?
Thanks,
Jim
914Sixer
Nov 12 2022, 03:07 PM
Check line bore. Pull head studs and have case decked on barrel spigots. Visually check crankshaft and camshaft saddles for damage or out of round.
Driver174
Nov 12 2022, 04:15 PM
The oil passages get tapped and plugged, or welded shut. Oil pressure regulator valve assembly needs modified I believe. The rear main seal needs a pressure relief passage. Case needs clearances for Cr moly rods. Epoxy or some king of coating for interior and exterior of case.
I’m hopping to find a complete list processes to perform.
barefoot
Nov 13 2022, 11:01 AM
Using new main bearing inserts, see if they're a tight fit into the brg saddles, if loose at all, the case needs line boring to 1st O/S
930cabman
Nov 13 2022, 12:30 PM
Other than being clean and straight/flat and within spec, build her up
