brant
Nov 29 2022, 05:42 PM
not sure what to call this....
mine must have vibrated loose and fell off somewhere between colorado and SLC for the Red Rocks event....
does anyone have a spare to sell?
its the cover plate that attaches to the S-bend on the rear attachment point
to connect the HE with the S-bend for the heater system...
thanks in advance
here is the picture of the one plate I have.. and the smaller one I need.
PCA7GGR
Nov 29 2022, 05:52 PM
PM me if this is the part you need - thanks
914Sixer
Nov 29 2022, 06:07 PM
Reproductions are available new. About $13. Heritage Parts Center
GaroldShaffer
Nov 29 2022, 06:32 PM
There is a difference in size left VS right. Left side is 3 1/8 inches between hole centers VS 2 7/8 on the right side. Make sure you get the correct one. I too have these available.
brant
Nov 29 2022, 06:44 PM
Thank you everyone
I need the drivers side small end
I measured Hole to hole at 2 and 3/8
Pictures I should have taken earlier
brant
And
brant
Nov 29 2022, 06:47 PM
I should add
Used is fine for a driver car like this one
PCA7GGR
Nov 29 2022, 06:52 PM
Mine is 3 1/8 inches between hole centers.
brant
Nov 30 2022, 08:01 AM
QUOTE(PCA7GGR @ Nov 29 2022, 05:52 PM)
My mistake
I couldn’t tell the dimensions well on yours and did not pm
But will send that message now.
Thank you!
Thanks everyone
Brant
brant
Dec 1 2022, 09:46 AM
bump...
still looking for the small end... driver side/Left
Garold, sent you a pm to see if you have one for sale also
brant
brant
Dec 2 2022, 07:39 AM
Still looking
Bump
brant
Dec 3 2022, 08:02 AM
Weekend bump
TheCabinetmaker
Dec 3 2022, 08:16 AM
I might have one, Brandt. I'll look in a bit
TheCabinetmaker
Dec 3 2022, 10:17 AM
Found one. Removed this from a driver's side "s" pipe
brant
Dec 3 2022, 11:42 AM
Curt
Thank you so much
It’s hard to tell length in a photo
Would you also mind checking the length between the bolt holes?
The one I need goes on the rear of the S connector with 2 and 1/4 bolt spacing
Thank you against n Curt
I’m excited to put things back together and move to the next project on the list
TheCabinetmaker
Dec 3 2022, 12:21 PM
Brandt, the holes are 3⅛ inches on center. It came off the the driver's side pipe from the fan shroud. I have a pair of repops. Neither are 2¼ inches
brant
Dec 3 2022, 12:33 PM
No problem Curt
Mine takes that size on the fan shroud end too
But the smaller size on the end that connectsn to the HE
I’m guessing it’s the small one that frequently vibrates loose and gets lost (like mine)
Where did you buy the repops?
Looks like I need to do that
The link in this thread is in Europe…. So I’ll see if there is a US option that doesn’t want more for shipping than the part costs
TheCabinetmaker
Dec 3 2022, 12:44 PM
Gotcha. The other end is just a piece of bent sheet metal. It's not like the shroud end. I'm not home till later. I'm sure to have one.
brant
Dec 3 2022, 12:53 PM
QUOTE(TheCabinetmaker @ Dec 3 2022, 11:44 AM)
I thought about making one because it’s simple
But I’m lazy
No rush
But if you do have an extra I’m a customer!
TIA
Brant
GaroldShaffer
Dec 4 2022, 08:33 AM
I need to work on my reading comprehension. This is what your are looking for?
