sjhenry1075
Dec 8 2022, 09:22 AM
Hey everyone,
I'm in the process of sourcing parts for my 2056 build. I was able to find 2.0 heads that will be rebuilt by a local machine shop, and I found a set of very nice 40 IDF Weber carbs. I'll also be using my 1.7 case.
My question is this: for the engine internals, where can I find these parts? I did see on the Fat Rimco website that they sell a short block kit for $2650 that includes the following:
FAT Camshaft FC 442 Camshaft / FC 440 If Smog
71mm Type 4 Crankshaft
2.0 Connecting Rods - Rebuilt
96mm Forged Pistons & Cylinders - Keith Black
WEB Lifters
Front Oil Seal
Rear Main Seal
Gasket Set - German
Engine Hardware Kit - Nuts & Bolts
Main Bearings - Silverline
Rod Bearings - Mahle
HD Double Thrust Cam Bearings (2 Sets of STD)
What does everyone think about the price? I know some would not refer Fat Rimco for an engine build, but they will just supply the parts, not doing the actual build.
Thoughts?
Montreal914
Dec 8 2022, 10:05 AM
Parts and machining: European Motorworks in Hawthorn, CA. Talk to George (Jorge)
http://www.europeanmotorworks.com/Camshafts: WebCam in Riverside, CA:
http://www.webcamshafts.com/If you have deeper pockets: Type4 Store.
For assembly reference videos, obviously Ian's video channel:
https://www.youtube.com/ @IanKarr And I also really like Van Svenson's detail work:
https://www.youtube.com/@vsvensonOthers will chime in...
Good luck with your fun build!
930cabman
Dec 8 2022, 10:22 AM
All good suggestions, may I add:
D Elgin camshafts
AA Performance Products
If you have experience with rebuilding these, do it yourself. Not too difficult, measure, measure and once again
914werke
Dec 8 2022, 11:16 AM
If you local machine shop has the ability to do the heads Its a good bet that can handle the Rod & Crank rehab which allows you to PU core parts for reasonable?
sjhenry1075
Dec 8 2022, 11:21 AM
QUOTE(914werke @ Dec 8 2022, 12:16 PM)
Good point, I never considered this. Thank you
sportlicherFahrer
Dec 8 2022, 11:28 AM
I picked up a nice set of pistons and cylinders and my valvetrain parts from Tabari Andrade on FaceBook. He's a machinist by trade, and modifies rockers and end stands for going to solid spacers and swivel feet. He also has some other trick stuff at fairly reasonable prices. Should be able to find him in one of the various 914 groups.
Don't bother with stock rods. The AA forged rods are pretty nice and weigh considerably less than the stock rods. Very close in weight to each other, too. Pretty sure they came with pin bushings already installed. Strongly suggest getting the upgraded ARP bolts.
AA Rods
barefoot
Dec 8 2022, 03:59 PM
You didn't mention any work needed on the cases, if the main bores are ovaled you'll need align boring & while at it decking the cylinder spigots is in order, you'll need a good shop to handle this $$
Barefoot
Dec 8 2022, 04:56 PM
Billy Ring
Performance auto works
Kerneysville WV
I was just there yesterday dropping off 3.6 parts (engine case work, heads, crank and rods) and picking up two sets of 911 heads.
He's around the corner from Summit Racetrack. Honest guy, No BS. Reasonable prices for high quality work. Our shop has been taking parts to him for years.
BeatNavy
Dec 8 2022, 07:25 PM
QUOTE(mepstein @ Dec 8 2022, 05:56 PM)
Billy Ring
Kerneysville WV
He did all my machine work (except Tabarri Andrade doing rocker arms) on my 2056. He's definitely a no BS guy, and he knows air-cooled Porsches.
Steve, what are your goals for the build? It looks like you're definitely going carbs rather than FI, but what else? Performance, CR, longevity, etc. Some of that may impact some of your purchase decisions.
sjhenry1075
Dec 9 2022, 05:57 AM
QUOTE(BeatNavy @ Dec 8 2022, 08:25 PM)
Billy Ring
Kerneysville WV
You're right, going carbs over FI. I'm looking for more zip. As you know, I'm a bigger guy, so I need some more power to get me around. I won't be racing the car, just looking for something that will get me places quickly, but also is reliable. At the same time, I don't want to push into the area where I'll need to upgrade the brakes and suspension. I believe a spirited 2056 would be in that area.
In regards to CR, honestly I don't know. I'd like to speak with an engine builder who can explain CR, and why I need to "shoot" for a specific number? I'm guessing the higher the CR, there's more heat so reliability becomes an issue. So what is a good mark to shoot for, 8.1.. 8.5..?
BeatNavy
Dec 9 2022, 06:34 AM
There's a ton of people here who can wax more eloquently than I can in terms of the tradeoffs, but in general:
Yeah, higher CR's produce more heat, require higher octane fuel, generally give you less "room for error" in the build, and may be less forgiving overall. If you're building this yourself, it's probably smart to err on the side of conservative (e.g., no more than 8.5-ish).
I point this out because I didn't really have this all mapped out when I purchased my first set of pistons (valve relief), and after I "stumbled" into my plan later I ended up having to buy a second set of pistons (KB flat top). Once the machine shop is done with your heads they should be able to tell you the combustion chamber volume, and then you'll really be able to determine how best to get to your target CR.
Carbs give you more flexibility in terms of cam selection, but again, more aggressive on the performance side involves tradeoffs on things like idle stability, mileage, etc.
All that said you can definitely get more zip without sacrificing reliability or making it a difficult build.
930cabman
Dec 9 2022, 08:48 AM
I am no professional engine builder, but have built several over the years. My recent 2056 came in around 8.8. She runs great, nice punch with Weber 44's and an Elgin street cam. My gut tells me anything over 9.0 is potentially asking for trouble (for a street machine) Keep us updated with your build
sjhenry1075
QUOTE(BeatNavy @ Dec 9 2022, 07:34 AM)
Don't you have a 2056? What cam did you use? If I understand this correctly, most of the power comes from the heads/cam/exhaust which all have to be tuned to work together, correct?
VaccaRabite
Dec 9 2022, 10:00 AM
QUOTE(sjhenry1075 @ Dec 9 2022, 09:48 AM)
Well, yes and no.
If you have a big cam they wants compression then you are going to need headers, and it’s going to want to live at the upper end of the Rev range.
But there are lots of cam out there. I happen to like the web 494 which gives a flat torque curve, is fine with about 8.6:1 compression (though it was also fine with 9.2:1 compression)
Compression makes power, and also makes heat. On my current 2056 I dialed back the compression in favor of less heat. It’s still a fantastic engine that I’m about to go drive over 100 miles away from home for the weekend.
Though they tend to be more expensive, I like the LN Engineering cam kits, and have one in my car (don’t recall the designation, but it’s similar to the 494 but with more exhaust duration).
Zach
sjhenry1075
Dec 9 2022, 10:08 AM
QUOTE(VaccaRabite @ Dec 9 2022, 11:00 AM)
Well, yes and no.
Zach
I think I'm going to go with Raby's 9590 and get the delux kit that comes with the chrome moly pushrods.
BeatNavy
Dec 9 2022, 10:50 AM
Steve, I have a 2056 with a 9590 sitting on my garage floor. I only ran it a few hundred miles before i swapped in the 2258 (also with 9590).
Interesting you've selected that cam, as that's marketed/designed as FI-compatible. I guess if you ever wanted to switch over to FI you could then do so. It's a great cam, although on the first start of the day it needs about 30 seconds of throttle-feathering before the idle settles in nicely.
BeatNavy
Dec 9 2022, 11:04 AM
I should also add that the 9590, when used with FI, is really designed (per Jake) for a target CR of 8.5 (max).
As Jake says, "it's all in the combo...."
sjhenry1075
Dec 9 2022, 12:00 PM
QUOTE(BeatNavy @ Dec 9 2022, 12:04 PM)
I read through some previous threads about cams which is how I got the idea. I noted how it can be difficult to keep it running when cold. now that you mention that it was designed for FI, I wonder if I should go with something a little more geared towards carbs. I just don't want to leave any power on the table.
JamesJ
Dec 9 2022, 12:17 PM
Not to pull away from OP's question, but it is related. I just had a 2056 "professionally" built with a Raby 9590 cam and am running 8.8:1 compression with stock L-jet. The car ran like a champ for 300 miles, then the engine locked up. When I remove the engine, I am considering lowering the compression. Is that a good idea?
Dec 9 2022, 12:53 PM
QUOTE(JamesJ @ Dec 9 2022, 01:17 PM)
You really have to figure out what made the engine lock up. It wasn’t the 8.8 compression ratio - at least not independent of other issues.
BeatNavy
Dec 9 2022, 01:58 PM
Yeah, in and of itself, the higher CR wouldn't cause the failure. I believe the target CR for that cam is primarily based on getting a usable vacuum signal for FI, particularly at idle.
Steve, I'm not sure if it's necessarily BAD to use that cam with carbs (others can comment). But the point is you CAN get a more aggressive cam, and at least a bit more HP, with carbs since you don't have to worry about a usable FI signal. Again, flip side is you could convert to FI down the road with that cam if you really wanted to.
JamesJ
Dec 9 2022, 06:46 PM
[/quote]
[/quote]
Yes, thank you. I know they are unrelated. My ? was should I lower the compression ratio while I have the engine apart.
If my comments help the OP, then great. Otherwise, feel free to PM me with comments.
TIA
BeatNavy
Dec 9 2022, 06:58 PM
If the car was running like a champ, then I wouldn't. Unless you find that it somehow contributed to the failure and need to for some reason.
sjhenry1075
Dec 9 2022, 08:54 PM
[quote name='JamesJ' date='Dec 9 2022, 07:46 PM' post='3044278']
[/quote]
[/quote]
TIA
[/quote]
Doesn’t bother me at all, post away
barnfind9141972
Dec 10 2022, 01:09 AM
[quote name='sjhenry1075' date='Dec 9 2022, 06:54 PM' post='3044307']
[/quote]
[/quote]
TIA
[/quote]
[/quote]
Jorge at European Motor Works did my whole engine and he makes custom cams depending on what you want whether it’s FI or carbs. He’s a one stop shop, Ian Karr on YouTube had his case fixed by him too. Great guy, knows his stuff and sells everything you need except for a 914
sjhenry1075
Dec 10 2022, 09:35 AM
[quote name='barnfind9141972' date='Dec 10 2022, 02:09 AM' post='3044321']
[/quote]
[/quote]
TIA
[/quote]
[/quote]
[/quote]
I wasn’t aware he could grind a cam. I think I’ll call him next week. Thank you for the idea
JamesJ
Dec 10 2022, 11:06 AM
@sjhenry1075 Jorge at EM is the one who built my engine. I had to fix some things that were not done properly by EM prior to my engine installation and I am not the only one on World who has had problems with EM. Cost wise he is too far away for me to pay to have the engine returned to him and shipped back to me. I may video the engine disassembly so both parties can agree on the problem.
@BeatNavy Thanks for the input on the compression ratio. It was running great, but for longevity purposes I richened up the fuel mixture just a hair so that it will run a bit cooler.
Montreal914
Dec 10 2022, 01:53 PM
QUOTE(JamesJ @ Dec 10 2022, 09:06 AM)
@JamesJ When you figure out what made your engine lock, please share.
sjhenry1075
Dec 10 2022, 07:26 PM
QUOTE(JamesJ @ Dec 10 2022, 12:06 PM)
I only plan on getting the parts, I’m going to assemble the engine myself.
JamesJ
Dec 10 2022, 11:21 PM
QUOTE(Montreal914 @ Dec 10 2022, 11:53 AM)
@Montreal914 Will do!
JeffBowlsby
Dec 10 2022, 11:47 PM
QUOTE(sjhenry1075 @ Dec 10 2022, 05:26 PM)
Be sure to check the vendors on the Nailed thread: Online Parts Resorces List.
sjhenry1075
Dec 11 2022, 08:17 AM
QUOTE(JeffBowlsby @ Dec 11 2022, 12:47 AM)
Thank you!
barringtonpro
Feb 6 2023, 06:59 AM
QUOTE(930cabman @ Dec 9 2022, 09:48 AM)
Can I ask which Elgin cam did you use? What rpm did it start to pull from? Also are you using 36mm ventures in the 44 webers or did you choke them down? Thanks
Frank
VaccaRabite
Feb 6 2023, 07:36 AM
QUOTE(barringtonpro @ Feb 6 2023, 07:59 AM)
Frank
When I was running my 2056 engine with 9.2:1 compression, it ran better with 44s then it did with 40s, but it was all top end power. When I moved to 40s I started having overheating issues and had a bear of a time getting the jetting right.
In the end I lowered compression to 8.6:1 and put on non-stock fuel injection. I lowered the compression to keep heat in check, and the fuel injection as I was tired of dealing with crappy carbs. Thousands of miles and many years later then engine has been a champ. A very fun motor for a 914.
By the way (not sure of the OP ever bought parts)
My 2056 used a 1.7 case, stock 2.0 crank and rods, Keith Black flattop pistons, bored out stock 2.0 jugs, ceramic lifters, Raby cam (now Len's Type4 Store), solid valve train spacers, etc.
Zach
DRPHIL914
Feb 6 2023, 09:38 AM
QUOTE(VaccaRabite @ Feb 6 2023, 08:36 AM)
Frank
Zach
@VaccaRabite Zach
My motor numbers etc are very close to yours, i think its just under or tat 9.0 CR and the 9590 cam profile, i think, with the new AA head castings, etc. and still using the D-jet with bored out TB, what TB /s are you using for intake and what FI control system?
Phil
Geezer914
Feb 6 2023, 10:35 AM
2056, 9550 cam, Hoffman RS heads, 9:1 CR, 50 mm modified vanagon throttle body. 1.8L Ljet with the AFR metering wheel 4 teeth richer. 93 octain gas.
VaccaRabite
Feb 8 2023, 09:37 AM
QUOTE(DRPHIL914 @ Feb 6 2023, 10:38 AM)
Zach
Phil
For my current motor, I am using a 1.8 intake plenum and runners, 1.8 airbox with a deleted flap box. I am using the goWesty throttle body (53mm IIRC over the stock 914 45mm). I have a thread on that somewhere.
Fuel and Spark are run via Microsquirt.
Spark is done through coil packs, and I have crank missing tooth wheel instead of a dizzy.
Before it was tuned how its tuned now, this motor dynoed at 127hp at the wheels, so at the crank its making about 140. I have not put it on a dyno with the current tune, and I pulled a LOT of fuel out of it (it was very very rich) so I don't know what power its making now. I can tell you it's a heck of a motor.
Zach
DRPHIL914
Feb 8 2023, 09:45 AM
QUOTE(VaccaRabite @ Feb 8 2023, 10:37 AM)
Zach
Phil
Zach
i do remember reading your thread on the go westy throttle body conversion for your intake. what coil pack sare you using and throttle body was a newer Bosch if i remember correctly so i think yours is very similar to what PMB is doing other than they are now moved to a Holley Terminator ECU so using injectors and coils that go with that and are developing a dizzy that has the cam and crank signals in it, but probably using same crank wheel sensor you are at first.
140 at the crank is a lot of hp for a 2.1 motor!! I feel like we can get this out of mine if ii can work out the details of the full conversion. not that i need that i think that Eric said they were seeing 110 at the wheels with t his set up on a stock 2.0 94mm stock cam etc. thats up from 75-90hp max for a d-jet 2.0 right, so 20hp gain. will see how it all pans out.
