DLewis
Dec 13 2022, 05:54 AM
Can someone tell me if a 916/6 and a 914/4 pedal cluster is the same?
Thanks, Dean
sixaddict
Dec 13 2022, 06:59 AM
Bruce says no.
There is lever/bracket on 6 versionfor hand throttle. Checked recently bc had a 4 and was hoping to use on a 6 I bought.
No deal so sold.
quote name='DLewis' date='Dec 13 2022, 03:54 AM' post='3044976']
Thanks, Dean
[/quote]
Jamie
Dec 13 2022, 07:48 AM
[quote name='sixaddict' date='Dec 13 2022, 04:59 AM' post='3044981']
Bruce says no.
No deal so sold.
Thanks, Dean
[/quote]
[/quote]
I've read here several times about a "hand throttle" on a 6 so what does it do? Sounds like it could be a manual choke or even a cruise control?
Steve
Dec 13 2022, 08:30 AM
The hand throttle is for carbs and there are after market kits if you want this functionality. It’s nothing but an extra plate on the throttle arm that a manual rod pushes against. Since my 3.2 injection has a built in choke, I did not care about this feature. Also when I had a 2.7 with webers, the engine would idle on its own within 5 minutes, so probably not needed accept in very cold climates.
https://914rubber.com/manual-throttle-actuator-kit-1
Cairo94507
Dec 13 2022, 08:31 AM
On a 6, the hand throttle is just that. It is intended for when one first starts the Weber equipped engine to hold the idle up so it warms up. The Weber equipped engines are notoriously cold-blooded and pop and backfire when cold. One would raise the idle to say 1500 and let it warm up.
Though not really safe, some would also use it as a cruise control on the freeways...(guilty as charged).
I have a 3.2 with Motronic injection in my car now. Initially, we did not reinstall the hand throttle. But I missed seeing it on the hump in front of the shifter. So we reinstalled it and it now works. If I were so inclined, I could use it as a cruise control. I will not as I just don't feel I could reach it as quickly as I could when I was 30 to cancel it.
sixaddict
Dec 13 2022, 09:54 AM
To specifically answer your question…….it allows you to increase the rpm’s in a cold start situation instead of having to hold accelerator pedal down a bit.
Functionally acting like a choke hence response from[
Injected engine.
quote name='Jamie' date='Dec 13 2022, 05:48 AM' post='3044999']
Bruce says no.
No deal so sold.
Thanks, Dean
[/quote]
[/quote]
[/quote]
brant
Dec 13 2022, 10:20 AM
except... a real choke... chokes the air inlet down and allows an overly rich mixture for starting....
this does not choke anything..
it allows you to pull the cable to a more open butterfly position on the carbs that causes it to rest at a higher RPM than the throttle stops on the carbs are set for.
dr914@autoatlanta.com
Dec 13 2022, 10:47 AM
the same except for the hand throttle which can be added to any 914 pedal cluster with this part: 914 423 260 00
QUOTE(DLewis @ Dec 13 2022, 04:54 AM)
Thanks, Dean
930cabman
Dec 14 2022, 06:00 AM
Could someone post a photo of this assembly? I am adding this to my Weber carbed/4
thank you
