I am providing some pictures and background on chemical dipping my 914.
I dropped my 914 chassis at the chemical dipper in September. To get the chassis prepared, I stripped everything off the chassis. Anything aluminum, like tags, has to be removed. Rockers panels cut open so heat transfer tubes can be removed. All nuts and bolts gone. The drain plugs are removed. I scrape off as much sealant as I can. Strip the sail cover. I stripped and cleaned off the doors, frunk, trunk, headlight covers and a few other small body parts which also got dipped. I used the door braces from Tangerine because I can adjust the distance and remount to the inside later. I drilled a few small holes in bracing tubes for draining per a request from the dippers.
After this was done, my daughter and I loaded it with a body cart onto a car trailer and took it for a drive. Once it gets to the chemical dippers, it gets lifted with a forklift and set in their lot to wait for its turn.
They started the chemical dip process this week. I got the first photos of the 914 chassis in a cage they built for a 914 they did a few months ago.
The chassis is pulled out of the hot caustic tank after 2 days. This is for paint and grease removal. This picture is right out of the tank before high pressure cleaning. I can see all the bondo and bodywork I have to address.
9 JANUARY UPDATE. They have finished the acid dip and high pressure washing. Bondo, adhesives from the vinyl top and factory Wurth sealant are all gone. Should be ready to deliver in a few days.
DaveB
