jdamiano
Dec 24 2022, 10:05 AM
Seems my passenger door isn’t latching properly all of a sudden. I really have to slam it for it to latch. The latch works fine if I flip it by hand. It’s seems like I need to move them closer together. The screws loosened right up but there didn’t seem to be any adjustment. Any advice is appreciated.
Lockwodo
Dec 24 2022, 10:21 AM
Try lubricating the latch mechanism first.
jdamiano
Dec 24 2022, 10:26 AM
I think I got it. I took the jam piece off and cleaned it up then used more force then I wanted to to push it out while tightening it down.
Cairo94507
Dec 24 2022, 10:43 AM
Take a look at your suspension console too.... just in case.
URY914
Dec 24 2022, 02:54 PM
^^^This.
The underlaying issue with 914 door problem and the first thing to break will be the door handle. Be careful. I can repair the flapper if it breaks.
mlindner
Dec 26 2022, 01:29 PM
And how does the door fit with rear fender edge...Door should be out just a little protecting fender edge from stones etc.
TheCabinetmaker
Dec 26 2022, 01:43 PM
You should also remove the latch in the door and thoroughly clean and relube it. It's the major cause of broken door handles.
