nivekdodge
Jan 12 2023, 06:39 PM
Like Bob Krantz, Powerplant in ....Powerplant out.Cha-Cha. I'm waiting for tranny parts and replaced the one pushrod seal that was leaking. The motor still has oil in it. Can i tilt it 10 degrees or so overnight to check for a leak?
Kevin
nathanxnathan
Jan 12 2023, 08:00 PM
The motor will more likely leak when it's hot and running. The oil is thinner at temperature and quite a lot of oil goes from the head to the sump via the pushrod tubes. To check it when it's cold and not running isn't going to show you very much. ...if I am understanding what it is you're asking. With the trouble to remove rockers etc, I would opt to redo all the pushrod tube seals at once.
Mikey914
Jan 12 2023, 08:04 PM
Won't be able to really check until it's running, but you will feel a positive engagement and DO -make sure you get the spring back in correctly. It's way softer than the push rods and will cut into them. So make sure it's not touching.
bkrantz
Jan 12 2023, 08:26 PM
QUOTE(nivekdodge @ Jan 12 2023, 05:39 PM)
Kevin
Hey, I didn't mean to start a trend.
nivekdodge
Jan 12 2023, 10:27 PM
Thanks guys,
Motor was just rebuilt and I know which one is leaking. Bob, I guess you really are my mentor!
Kevin
930cabman
Jan 13 2023, 05:53 AM
QUOTE(nathanxnathan @ Jan 12 2023, 09:00 PM)
r_towle
Jan 14 2023, 04:15 PM
QUOTE(nivekdodge @ Jan 12 2023, 11:27 PM)
Thanks guys,
Kevin
You can remove and replace the seals with the motor in the car.
930cabman
Jan 14 2023, 05:51 PM
QUOTE(r_towle @ Jan 14 2023, 05:15 PM)
Thanks guys,
Kevin
I recently did this and as I recall cylinders #1 or #2 were difficult
r_towle
Jan 14 2023, 07:11 PM
You do not need to remove the tube from the engine to simply replace the seal. If you must remove the whole tube for replacement, you sadly will need to drop the engine.
Otherwise, remove rockers, pull tube and pushrod out far enough to replace seal, then install again.
Rich
nivekdodge
Nov 17 2023, 07:00 PM
I haven't tried this a second time but I am going to over the winter. I've red about polishing the mating surfaces and plan on that.
Bob
Are yours still dry?
Kevin
bkrantz
Nov 17 2023, 07:33 PM
QUOTE(nivekdodge @ Nov 17 2023, 06:00 PM)
Bob
Kevin
Yes--so far. But I hate to claim final victory.
nivekdodge
Nov 17 2023, 09:00 PM
Superstitious like that huh?
Jack Standz
Nov 18 2023, 01:50 AM
QUOTE(r_towle @ Jan 15 2023, 08:11 AM)
Rich
Not sure what you meant to say, but you do not need to remove the engine to replace the pushrod tubes or seals.
rjames
Nov 18 2023, 02:32 AM
QUOTE(Jack Standz @ Nov 17 2023, 11:50 PM)
Rich
It’s not fun with the engine in the car, but it’s doable.
