Petepat
Jan 14 2023, 06:21 AM
Anyone know where I could buy a new or reconditioned blower heater for rear engine compartment or better still a re-con kit as the main bush/bearing is shot. I can see plenty of blowers for the front but not back. Thanks in advance.
930cabman
Jan 14 2023, 07:26 AM
You might find a small motor shop and rebuild, most of these are easily rebuildable and save $$
rhodyguy
Jan 14 2023, 10:02 AM
There are 2 styles. The single outlet that has it’s own bracket that’s welded to the shelve and the dual outlet that mounts on the engine shroud. Which style do you need?
Petepat
Jan 14 2023, 10:51 AM
QUOTE(rhodyguy @ Jan 14 2023, 11:02 AM)
The dual outlet one.
914sgofast2
Jan 14 2023, 12:52 PM
I believe the fan’s motor itself is the same as used on VW Bay Window buses from 1972 to 1979 that had the Type 4 engines.
Petepat
Jan 15 2023, 10:00 AM
QUOTE(914sgofast2 @ Jan 14 2023, 01:52 PM)
thanks for thatI'll check it out.
