QUOTE(Robarabian @ Jan 15 2023, 09:32 AM)
Usually, you do the following to initially seat rings and break in the valve train:
1 Break in oil
2) Crank but don't fire and make sure you have oil pressure building.
3)Start it and bring it up to about 2K RPM's (Time it if possible or get it close)
4) Hold that position for about 20 minutes....
5) Monitor oil pressure during the entire event and watch for leaks, smokes, noises etc....
Shut it down and let it cool.
Once you are through that, you an break in as normal.
I agree with this
But add to change the oil after that initial 20 minutes
Then more break in oil after checking the valves.
Another oil change after a few hundred miles
