My shifter was broken at the weld, so I replaced it.
I followed the directions someone posted about replacing the springs, which worked like a charm.
Now, I'm trying to get it all back together. My engine is out for a rebuild so the shaft is loose.
1. The linkage to the shifter, should that be set at a certain angle? And how tight should that nut and bolt be?
2. Trying to get the shaft in the linkage seems to be impossible. I can only think of trying to set it and then tap it in from the firewall. But I can't do both things at once. Am I missing something here?
Thanks,
Victor
