QUOTE(JeffBowlsby @ Jan 20 2023, 07:53 PM)
lose the dielectric grease. Not good in any environment where it can attract dirt.
Public service announcement.
Definition of dielectric: insulating; does NOT conduct electricity.
Really has no place in 12v automotive wiring. Want to use on high voltage spark plug wire terminals to help prevent condensation and arcing down wet wires? Sure - that is what it is intended for.
Sounds like you pulled the power supply relay - not the blower (heater fan) relay. Power relay feeds power to the fuel pump relay and the ECU.
Heater relay would not have any effect on starting the car unless something is massively miswired on your car.
Click to view attachmentBench test the relay - may have gone bad. Old relays are notoriously fragile. The act of pulling it out of the relay board may have caused a connection inside the relay to break.
Pins 85 & 86 are the control solenoid ; apply 12v pin 85 and ground pin 86
Should hear and feel the relay click when the solenoid is powered.
pins 30 and 87 are the contacts; should measure zero ohms with solenoid powered.
