QUOTE(76-914 @ Jan 23 2023, 05:32 PM)
QUOTE(Root_Werks @ Jan 23 2023, 11:51 AM)
Done both, welded material on and rotated out. Oil and ViceGrips, mostly works.
Had good luck with reverse drill bits. Start as small as possible and keep upsizing. Usually the friction heat and constant reverse torque turn out the broken stud.
Yes, me too. But I'd never tried to weld a broken stud that was recessed in the head. BTW, a 4" pipe wrench works much better than vice grips as it continually tightens its grip with additional force. IOW, it won't slip like vice grips.
A 4" pipe wrench works very well.
Much like a pipe wrench a vise grip works far better when positioned perpendicular
to the stud and rotated with the upper jaw dragging the stud rather than
pushing......the principle that makes a pipe wrench work so well.
I've also had luck welding onto a surface broken stud.....~60% success
