Petepat
Jan 24 2023, 10:44 AM
So I have the 1.8 L engine which looks like it was injection but now has twin carbs so my understanding is that the timing for a 1.8 is 4.5 BTDC but does that need to change because of the now carburettors? And yes I'm having problems starting!
TheCabinetmaker
Jan 24 2023, 02:22 PM
The carb guys will correct me. But I think it's 27⁰btdc
r_towle
Jan 24 2023, 02:33 PM
ClayPerrine
Jan 24 2023, 03:20 PM
The timing is different for a 1.8L engine.
It is 7.5 degrees at 900 RPM.
Clay
r_towle
Jan 24 2023, 03:25 PM
QUOTE(ClayPerrine @ Jan 24 2023, 04:20 PM)
Clay
properly documented in the article posted.
It also seems that 25-32 at 3k rpms is across the board....not sure though.
the chart goes by distributor number...which I don't know.
Rich
Osnabruck914
Jan 24 2023, 08:16 PM
F.I. calls for 27 degrees at throttle, which never works for carbs in my experience. You'll be looking for 29-32 degrees. Too low and it will bog out on acceleration and chug-chug in cruise. Too high and you lose torque, run HOT, and your engine will sound like a sewing machine. Also, make sure your not starving for gas with too small main and idle jets. With carbs, go rich and go advanced. With experience you will find the sweet spots.
Osnabruck914
Petepat
Jan 25 2023, 04:14 AM
Thanks for all the feedback and info guys and as has been said 1.8 L engines are different with only 7.5 degrees BTDC. HOWEVER are all 1.8L engines originally injection and if they were charged to Webbers at a later stage would that change the timing settings?
ClayPerrine
Jan 25 2023, 06:39 AM
QUOTE(Petepat @ Jan 25 2023, 04:14 AM)
The 1.8L engine had carbs on it for Europe. It used the same distributor. And of all the stock distributors, the 1.8L distributor is the one to have for carbs. So set it to the factory settings i.e. 7.5 degrees at 900RPM.
Petepat
Jan 26 2023, 01:58 PM
QUOTE(ClayPerrine @ Jan 25 2023, 07:39 AM)
_This 914 was first registered in California before it came to France, so would that had made it an injection?
rhodyguy
Jan 26 2023, 04:30 PM
Until you figure out and fix the fuel supply system, you’re spinning your wheels. Figure a cold start is key to on, hear pump whir, 3 full, kinda slow, pumps of the pedal, engage starter, when it starts feather the peddle a bit and it should idle for you. What is your idle RPM when warm? A clean engine bay is more fun to work in.
dr914@autoatlanta.com
Jan 26 2023, 04:36 PM
27 degrees btdc at 3500 rpm, you could bump it up to 30 but no more. HOWEVER first check the dwell and set it to 50 or the timing will mean NOTHING
QUOTE(TheCabinetmaker @ Jan 24 2023, 01:22 PM)
