QUOTE(fixer34 @ Jan 28 2023, 09:23 PM)
The AI instructions didn't tell you what to do?? Sorry, I couldn't resist...
So tell us again what you want to do (or think you want to do). Replacing the struts does not require removing the steering rack. You may or may not have to remove the control arms depending on whether you can separate the lower ball joint from the control arm.
If you want to take each side off, first remove the caliper. You will need to separate the brake line because it runs thru a retainer on the strut. Do it quick and you won't lose much brake fluid. Then pop the tie rod end out. The torsion bar adjusting screw (bolt?) needs to be backed out to remove the downward tension. If I recall, there are 2 mounting bolts in the front and two in the rear. Remove those and the upper strut nut and it comes out in your hands.
Where in Chicago/area are you? I'm in NW suburbs.
@fixer34 Good one
I'm in Mt. Prospect. This is my first 914 and the first car I have ever attempted to work on. So, I really have no clue what I'm doing.
I set out to refresh the front struts. They were shot. The driver-side ball joint was split as was the tie-rod end. The passenger side wasn't as bad but I planned to replace both sides.
I was going to upgrade to Turbo tie-rods. This is where I came off the rails. Unfortunately, I watched the video I referenced. That video skips over the removal of the support rack (not sure what to call it). That is when I wrote my post. I was really lost.
I've reversed my decision on the Turbo-tie rods since I posted. It's just too damn cold in my garage and my old bones can't take it. So, for now, I'm just changing the ends of the tie-rods.
So once my parts get here I'm just hoping I can get everything back together
