QUOTE(SirAndy @ Feb 2 2023, 08:08 PM)
http://www.914world.com/specs/SirAndyCarbFuelPumpRelay.phpWhat's wrong with the stock power supply?
PS: No need to cut a single wire ...
He has a 75, so the FP connection is under the tank.
Your car has one 12Ga black/red wire from the 14 pin routed through the harness to where it ends under the fuel tank. Be sure to insulate this wire under the tank so it does not short to ground.
Consider opening the main harness casing at the left side of the engine bay where it routes between the relay board and the snorkel tube, and locate the black/red wire to tap off it for your fuel pump. Run a dedicated ground to one of the screws at your pump.
