QUOTE(jmargush @ Feb 8 2023, 05:17 PM)
I need to fabricate a heater cable due to running Tangerine Racing heat exchanger.
Does anyone know what gauge of wire the cable is and is there a certain type of steel wire that I should be looking for?
If you want to replace the cable, you should use music wire, around .045-.050" dia. However if your original cable is in usable condition it's within a couple inches I think, to reach the new position of the flappers.
I was taught a simple method to extend a too short flapper wire is to add a long small diameter cotter pin as an extension, with the cable secured around the loop of the pin.
I have a small roll of .051" music wire here. I'd be happy to send a suitable length to you to make a new cable.
