r_towle
Feb 8 2023, 06:31 PM
Hi,
I have a 997 (this feels like the start of a support group thing)
This car has an electric front hood latch.
So, the battery needs to be hooked up to open the front hood where the battery is...
Its not logical, but Porsche put in a shortcut.
So, go to the fuse box inside, pull out a red lead, and hook up a 12VDC battery to this lead, and chassis ground...
Hood opens.
Instead of using a full size heavy car battery, I went and bought a lithium battery "jump box" thing
Schumacher SL1639 Lithium Portable Power Pack and 1000A 12V Jump Starter
So, it will not work.
We ended up getting a full size battery, with jumpers, just to open the hood, so we could reconnect the battery.
My question is...WHY does it not work?
When I put my meter on it, I see 16VDC
ITs fully charged.
Its on.
The Tech support told me the unit can only be used for jump starting a car.
The mechanic at the shop told me he also had this issue, and the unit needs to see a load??
I will return this if it will never work...but I really need to know why it won't work.
I can get a motorcycle battery, or some other unit that will take care of my needs...but this thing should work...yet it does not.
Anyone care to explain electricity to me?
Rich
mgphoto
Feb 8 2023, 07:09 PM
2 words Ohms Law.
worn
Feb 8 2023, 07:22 PM
QUOTE(mgphoto @ Feb 8 2023, 05:09 PM)
2 words Ohms Law.
I raise you with ROYGBIV. I guess that the jump pack is supposed to drop a lot of power against a relatively low resistance. The circuit to open the trunk might not meet the sensor’s expectation, and the jump pack will not fire. These lithium batteries aren’t just batteries. They come with brains meant to prevent usefulness. I wonder if a nine volt battery would do the trick. I have a stack of useless Amazon batteries for tools. I cannot charge them, but expect they could be charged if the defective chips would let them.
r_towle
Feb 8 2023, 07:36 PM
Sorry….I read ohms law and I don’t get why this jump pack won’t work, yet I see the voltage with a meter.
I guess I will return it and get a small lawnmower battery or similar
914GT
Feb 8 2023, 07:38 PM
Do you see 16v with it attached to the load? I suspect the voltage is dropping too low as the supply can’t provide enough current to drive the solenoid. Or as mentioned above a current limiting circuit is involved.
76-914
Feb 8 2023, 07:43 PM
Rich, buy a 12v cordless drill battery or 8 flashlight batteries.
r_towle
Feb 8 2023, 07:47 PM
QUOTE(76-914 @ Feb 8 2023, 08:43 PM)
I will tomorrow…so I can open the trunk again
Terrible design.
r_towle
Feb 8 2023, 07:48 PM
QUOTE(914GT @ Feb 8 2023, 08:38 PM)
Honestly, for $120 buck…it’s a heavy flashlight …
Bringing it back tomorrow.
Feb 8 2023, 08:04 PM
The jump packs are really great in the usual situation you buy them for. We use one at the shop all the time. Porsche’s always seem to have a dead battery when they need to get on the trailer. I bought one for my daughter after she had to deal with a dead battery and no good way to get close with jumper cables. We got AAA to tow it but a jump pack would have fixed it.
Worth their money X 10 when you really need it.
r_towle
Feb 8 2023, 08:37 PM
I have larger jump packs..
I wanted something light and small to open the trunk multiple times while I move this car around with no engine…and main battery unplugged.
Sadly, I only have an open trailer, so the hood must be closed.
I will get something small tomorrow.
We have a store nearby named “batteries plus”
They will have something…
bkrantz
Feb 8 2023, 09:00 PM
Not sure about 997s, but my 991 has a hidden pull wire attached to the front latch, in addition to the fuse box jumper thing. The pull cable can be found hiding behind the front left fender liner. Some people relocate this or add an extension so they can pop the frunk lid without removing the fender liner.
r_towle
Feb 8 2023, 10:38 PM
Yes we found and tested that pull.
Can you imagine a few scenarios…
Dead battery at night…wheel locks on car, tools in trunk.
How about dead battery and a tow truck driver…who has no clue about the front trunk jumper.
Sorry, but it’s just a dumb design.
theer
Feb 9 2023, 12:28 AM
Rich- I had the same thing happen to a friend’s 911 (I only run with the crowd owns these fancy-pants cars, don’t have one myself.). Anyway, I used a regular jump pack - the big heavy one- and it worked fine.
I have also used the same jump pack to run the 12v winch on my car trailer. Works fine for that, too. Maybe the little lithium ones have some kind of security/safety BS thing to protect it…?
Geezer914
Feb 9 2023, 07:00 AM
12V alarm battery or 12V lawnmower battery.
StarBear
Feb 9 2023, 07:35 AM
QUOTE(mepstein @ Feb 8 2023, 09:04 PM)
Yep; have one in each of our regular cars. Have to remember to keep it charged up, though! On the first of every even month. Put one in Frogger for the NE Gathering trip.
Front yard mechanic
Feb 9 2023, 07:44 AM
My cheap hf battery charger has a chip in it it has to sense a load drop before it will kick in. Try to find a jump pack that has instant on.
GregAmy
Feb 9 2023, 07:48 AM
QUOTE(Front yard mechanic @ Feb 9 2023, 08:44 AM)
Yup. You probably need one that has a 12V cig plug to do what you're trying to do.
I'm guessing 5V from the USB ain't gonna be enough.
Superhawk996
Feb 9 2023, 08:03 AM
QUOTE(theer @ Feb 9 2023, 01:28 AM)
The thing everyone loses sight of is that Lithium-ion batteries are not “just” a battery.
Lithium ion batteries are volatile. As such, almost everything except a raw cell has a battery management system to protect them from being fully drained below 10-20% of capacity. Likewise they are protected from over charging. They are protected from short circuits. Lithium-ion batteries can self oxidize (I.e burn) due to thermal runaway if the cell gets too hot from being charged or discharged to fast. This is all done by a microprocessor (and other electronics) controlling the battery. Even single cells can have a very simple battery management system on them.
If the battery management system wants to limit current in or out it can do so. In your case, current is being limited until it sees a load that looks like a battery (connected proper polarity) and a low resistance load like a starter motor.
Not just a battery.
Click to view attachmenthttps://lygte-info.dk/info/battery%20protection%20UK.htmlNote: mechanical engineer but don’t hold it against me - I play with electrons too!
bzettner
Feb 9 2023, 08:15 AM
QUOTE(r_towle @ Feb 8 2023, 10:38 PM)
My 986, of course, has the emergency pull wire. I relocated mine into a place that can be reached thru the air dam. It's saved me several times.
jd74914
Feb 9 2023, 01:23 PM
QUOTE(Superhawk996 @ Feb 9 2023, 09:03 AM)
Lithium ion batteries are volatile. As such, almost everything except a raw cell has a battery management system to protect them...
Those protections are there for good reason.
Some jump boxes (looking at you Noco Genius) have override buttons so you can start a battery-less car with them. The button is a tacit user acknowledgement that the situation is appropriate for the given use. In any case, they work pretty good for things like starting diesel tractors missing a battery, etc.
87m491
Feb 9 2023, 02:09 PM
QUOTE(r_towle @ Feb 8 2023, 08:38 PM)
Long story short, what good is a "jumper pack" if you can't get it to the battery?
I'm with you, return it.
fixer34
Feb 9 2023, 07:26 PM
I've been around electricity and electronics enough, but not convinced that a 'jump pack' that weighs 4 pounds and fits in my pocket is going to start a car that normally needs a 400CCA battery.
Anyway, get one of these with F2 terminals (same as all the push on connectors in the 914). Sealed lead acid so you can store it pretty much anyway you want.
https://www.homedepot.com/p/MIGHTY-MAX-BATT...22495/323133872Holds a charge for 6 months or more, put it on a regular batter charger to refresh.
r_towle
Feb 9 2023, 07:34 PM
Yah…I may go order a Milwaukee power access thing that clips onto a 12 vdc rechargeable battery..
targa72e
Feb 10 2023, 12:21 AM
I will just echo what others have said. The device you have is intended to start a car with a battery at low charge. It has smarts to keep bad things from happening. It is like most storage trickle chargers, it will not provide a voltage if it does not see the proper load. So if battery is disconnected then "jumper post" in car can not be used with jumper pack to power the car as it does not see the required parameters. If you get a cheap dumb plug in battery charger that just outputs no matter what then it will work in the way you want.
john
GregAmy
Feb 10 2023, 07:48 AM
Of course, why in the hell Porsche put the battery in location that is inaccessible when the battery is dead is a question all on its own...are car owners supposed to carry around a spare 12V power source hanging off their key chains...? SMDH...
Feb 10 2023, 07:59 AM
These will fit in the palm of your hand and start a large truck with a dead battery. I’ve personally used it on the truck. It’s what I purchased for my daughter. Gets high reviews.
fixer34
Feb 10 2023, 05:03 PM
QUOTE(mepstein @ Feb 10 2023, 07:59 AM)
Sorry, there is no way in hell that unit will provide 1000amps unless you measure the time in milliseconds. The clamps themselves would melt after 2-3 seconds.
Superhawk996
Feb 10 2023, 05:22 PM
QUOTE(fixer34 @ Feb 10 2023, 06:03 PM)
Agree on the 1000A rating - marketing hype.
Ratings are like cheap stereo ratings of old - optimistic and rated at peak.
However, research how lithium ion batteries perform. They can be designed for peak energy or peak power. A single 18650 cell can deliver 30A in short repetitive bursts. Pouch cells can put out even more current due to large surface area of the anode and cathode. This ability to deliver very high power out of such a small package is what makes Lithium ion batteries dangerous if used improperly and/or short circuited.
It is VERY EASY for these small jump packs to crank a completely dead vehicle (with or without vehicle battery) with a very small footprint and light weight. Used to use them a couple times a week. Way better than hauling around those old lead acid jump packs.
r_towle
Feb 10 2023, 05:51 PM
Funny timing
I left the trailer hooked up which kills my cayenne battery.
The “Schumacher jumper pack” I bought did nothing.
When hooked up it beeped with an error.
So I am returning it tomorrow.
Superhawk996
Feb 11 2023, 08:51 AM
QUOTE(r_towle @ Feb 10 2023, 06:51 PM)
Funny timing
Huh?
So I’m looking on Amazon - 8% 1 and 2 star reviews and not just a couple of them
Well that’s bull
Download user manual:
JUMP STARTING A VEHICLE ENGINE
NOTE: Use model number SA858 jump cable.
IMPORTANT: Do not use the jump starter while charging its internal battery. IMPORTANT: Using the jump starter without a battery installed in the vehicle will damage the vehicle’s electrical system.
NOTE: The internal battery must have a charge if at least 40% to jump start a vehicle.
NOTE: Cold weather may affect the performance of the jump starter’s lithium battery. If you hear only a click and the engine does not turn over, try the following:
With the jump starter connected to the car battery and the green LED illuminated on the smart cable, turn on all lights and electrical accessories for one minute. This draws current from the jump starter and warms the battery. Now try to crank the engine. If it does not turn over, repeat the procedure. Extremely cold weather may require two or three battery warmings before the engine will start.
I assume you’ve tried this
I’ve used plenty of these little jump packs on vehicle batteries at are completely flat. Either the unit isn’t big enough - but it certainly is for a Cayenne or Schumacher is really missing the boat.
Send that puppy back.
r_towle
Feb 11 2023, 03:17 PM
It’s cute, but I’m returning it because it does nothing.
I will suck it up and get another big heavy one.
Meanwhile I used my generator battery to deal with my immediate issue.
I’m really amazed how useless this thing is.
