BillJ
Feb 13 2023, 12:31 PM
Ok. So i have a custom made dash that is much ligther and does preserve the pod frame. Does anyone have a nice pod they want to let go of? Dont care about the rest of the dash i just need the pod. I really dont like how unfinished this all looks.
sixaddict
Feb 13 2023, 12:38 PM
Bill
I have several dash pads but want to be sure I understand what you need. Is this cutting the part you don’t need.
If so will check the ones I have and do that but concerned I don’t understand what you need.
Thanks
Terry
BillJ
Feb 13 2023, 01:04 PM
I dont need anything except the surround for the gauges. The whole long dash will not be used. My hairbrained scheme is to cut smooth to the edge and cover in alcantara so that it looks decent.
BillJ
Feb 13 2023, 01:08 PM
Basically just this:
sixaddict
Feb 13 2023, 01:45 PM
That’s what I thought ….
Heading to storage to see if I have a good one.
Forget your number so pm and I will test you what I have .
Terry
Krieger
Feb 13 2023, 09:10 PM
Make one out of a piece of aluminum. Make it out of card board first then transfer it to the aluminum.
BillJ
Feb 13 2023, 09:15 PM
There are many things i can do on the car. Basic wiring, suspension replacement, painting, simple mechanical swaps, brake work, etc.... but metal bending is a damn art and that shape is really complex particularly if you want it to fit neatly into the dash as designed. I definitely lack the skill.
Dominic
Feb 13 2023, 09:27 PM
I have a metal frame for the gauges for sale in my post linked below:
http://www.914world.com/bbs2/index.php?sho...=353047&hl=
BillJ
Feb 13 2023, 09:33 PM
I don't need the frame for the gauges. I need the dash pod that covers the whole thing.
BillJ
Feb 14 2023, 09:51 PM
Still searching
Jett
Feb 14 2023, 11:01 PM
How about an art project?
Create a cardboard template of the desired pod shape and attach to the dash frame with tape.
Cut two inch wide strips of fiberglass, soak in resin, and apply until you get the general shape and thickness.
When dry, apply some type of flex filler bondo, and sand.
Create mounting holes.
Cover with material and install.
Disclaimer: experience comes from watching Texas Metal
the upholstery fellow is amazing!
914werke
Feb 14 2023, 11:17 PM
QUOTE(BillJ @ Feb 14 2023, 07:51 PM)
Still searching
Bill I can cut you one tomorrow.
Feb 15 2023, 06:59 AM
Reminds me of this car
BillJ
Feb 15 2023, 10:39 AM
QUOTE(914werke @ Feb 15 2023, 12:17 AM)
Still searching
Do tell!
914werke
Feb 15 2023, 11:38 AM
A few years back I connected with a guy who had a mobile biz (big box van) who'd float to the various auto dealerships &
collision repair shops in the area doing vinyl repairs.
He could fix a tear in upholstery or crack in a dash & color match it like it wasn't there.
This was before various players started reproducing dash tops so I tossed him a take-off that had a crack & asked him to make it look like new.
It turned out awesome so I set him up with a dash frame to make future work easier, he turned out 4 or 5 then POOF vanished.
In the mean time I stashed away a bunch for that service but then Mark & George started making repop's. So I still have a bunch of cores I haven't tossed out.
BillJ
Feb 15 2023, 01:34 PM
Very nice of you! The ones Terry had were pretty trashed and would be too much work. I really appreciate it.
914werke
Feb 17 2023, 12:03 PM
well out of about 12 I had rat-holed, NONE turned out to be perfect in that pod shroud area, sorry.
BillJ
Feb 17 2023, 01:09 PM
Ugh. The search continues
Al Meredith
Feb 18 2023, 05:34 PM
I sent Bruce Stone about 6 of these and he powder coated them. He may still have some left. AL
BillJ
Feb 18 2023, 09:29 PM
How would he have powder coated them? These are foam and rubber right? Did you make some.out of.metal? That would be prefect!!!
914werke
Feb 18 2023, 09:37 PM
QUOTE(BillJ @ Feb 18 2023, 07:29 PM)
How would he have powder coated them? These are foam and rubber right? Did you make some out of metal?
He's thinking of
THESE
burton73
Feb 18 2023, 09:57 PM
This is not a big deal to the right guy,
Just get an old bad dash and have someone with a bandsaw cut what you want and then work on massaging the shape and covering that form with the end material. Get the elements and then you get the upholstery guy to work his magic if you don't have that skill set.
If you do not have that skillset you are going to need to spend some money with someone that does.
Bob B
BillJ
Mar 11 2023, 04:56 PM
Update on this is i was able to procure an old dash and am having a shop that does wonderful interior work take a whack at making the pod portion work. Will see how it comes out!
