Full Version: Pedal floor boards
nivekdodge
Little things are annoying me. Is there a process to get the floor board back aroung the pedals without disconnecting the accelerator from the cable?
Kevin
bdstone914
No need to remove the cable. Remove the two bolts that mount the pedal to the floor. If they are rusty soak with a good penetrant.
Remove the pedal covers. Hold the board horizontal and slide onto the top of the pedals and then down.
76-914
It help to remove the rubber pads from the brake and clutch pedals. beerchug.gif
914 RZ-1
It's not easy, but it can be done. It's like a puzzle that only goes together one way. I can't remember exactly how I did it, but you twist and turn and it will go over the pedals. It's hard to explain! Patience!
Garland
QUOTE(914 RZ-1 @ Feb 15 2023, 10:17 PM) *
Pop the Excelerator rod off the back of the excelerator pedal. Then the board will go in, with some movement of the clutch and brake pedal’s.
nivekdodge
QUOTE(Garland @ Feb 16 2023, 12:56 AM) *
But then to get the accelerator rod back in I have to remove the floorboard sawzall-smiley.gif
dr914@autoatlanta.com
YES Just snap the rod off of the pedal and remove the two pedal pads and then the two allen bolts and turn at an angle to remove
QUOTE(nivekdodge @ Feb 15 2023, 07:11 PM) *
Kevin
Garland
QUOTE(nivekdodge @ Feb 16 2023, 01:31 PM) *
Only remove from back of pedal socket. Just pull, the pedal towards you.
930cabman
QUOTE(76-914 @ Feb 15 2023, 09:43 PM) *
Yes, and wiggle her in there
nivekdodge
THanks Guys,
I did get it back on !!!!
Kevin
