QUOTE(rgalla9146 @ Mar 3 2023, 06:43 PM)
The dealers did whatever was easiest and cheapest so they put any antenna wherever they liked.
The factory Info Sheet we got for our car indicates: M453 Blaupunkt Frankfurt US retractable antenna with loudspeaker & noise suppression. I realize there is debate about whether the factory actually installed any radios. There is an existing hole in our driver fender. It appears to be 19mm.
there is hole for the antenna wire to enter the fan housing/wiper motor area from the wheelwell. It is on the drivers inner fender only. It has a rubber plug in it and is on every car from 1970 to 1976. There is another hole to pass the wire into the radio area.
Second, there is a hole in the pinch weld flange at the rear of the drivers fender well that is provided to attach a support bracket for the tube of the antenna.
This is very helpful information. Thanks for sharing this!
Antennas have been discussed here before. I can provide more info and pics this coming week.
I have been through a LOT of antenna threads. Both here and on 911 boards. I'm having a really tough time distinguishing between the wide variety of Hirschmann to know what's correct for 1970 914-6. The differences in length, tip colors, keys, base angle, etc. makes it easy to get them confused.
I have plenty of other fish to fry, so I shouldn't be obsessing on antenna right now. That said, I will need a radio! So I might as well get the right antenna.
