I have a 914-6 conversion. It has the rear parking brake shoes inside the rotor. Essentially a rotor/ caliper disc on the circumference, and a mini drum brake on the inside. One side is a little bit stuck on intermittently when I drive. I suspect the shoes weren’t put on correctly as some lack of retainer springs are allowing for the break shoes to shift inside the drum space. I’ll open that up again tonight to take a peak as to what might me missing.
Do the 914 six parking brakes share the same configuration / parts with the early 911’s? I need to reference a diagram for the correct brakes and likely buy a few miscellaneous springs/ retainers to keep the shoes from shifting.
Thanks in advance
Todd
