QUOTE(914_teener @ Feb 28 2023, 10:19 AM)
QUOTE(Aeromek @ Feb 28 2023, 08:45 AM)
Thanks again for the added info. above. All great info. and all makes sense. Haven't had time to clean and lube the distributer yet, But I did swap the hoses. Didn't help much as both have a significant amount of vacuum. In doing so, I found an open port on the throttle body. I see the reply above with a diagram that shows both hoses going to the throttle body (not the plenum). The diagram isn't very clear which port goes to retard and which goes to advance. I realize the lesser vacuum should go to retard, but thought someone might know which port go's where. One port is vertical (points up) one is horizontal (point out the side). So question is - Horizontal port to advance or retard ? Vertical port to advance or retard ?
Again, I bought the car this way, so just trying to figure it out. Still idles and runs fine with advance line disconnected and plugged. Car is a 1972.
Think about it. The throttle has a throttle plate. When closed, there are two ports. The port behind the plate has the highest vaccum AT IDLE when closed. The port in ADVANCE of the plate has the least if any. Imagine the plate in slow motion opening and what happens. So the port behind the plate is the retard port and the port towards atmopshere WHEN closed is advance. When partly opened the retard port starts to drop in HG and the advance starts to increases in HG. With the throttle plate fully open....both drop to zero.
Disagree with what Rich says....it is not worthless for a D-jet engine...in fact on part load when the engine throttle plate is only slightly open, the timing won't respond as quickly and for d-jet slighly lean....ping. Not good.
Check the vaccum ports on the dizzy vaccum can..both of them for holding vaccum like the MPS. If it won't hold vaccum it's junk and get a 123 distributor.
There is a drawging around here somewhere that shows this...from the factory manual.
@Aeromekcorrect ---> but only half the story.
the spring in the vac mechanism snaps off the retard as soon as you open the throttle from idle.
the retard at idle is there for emissions. at least in the L jet and i suspect the same for earlier D jet.
but you would never take off from the lights with the engine retarded as it is due to vac can. so.....its designed to immediately snap off. the minute you open the throttle to go.
the vacuum in the engine drops but its really the spring that snaps off the retard and snaps it off fast without the vac present, in either of the throttle ports.
generally the advance does not come into play until you are steady state cruising with the throttle only partly cracked open. then the vac builds in both ports as you suggest.
since advance can is bigger than retard can its designed to give you the kind of advance you would have gotten in much earlier VWs with single advance vac cans.
ie advance can - retard can = actual real advance --- which is added to where mechanical advance has the timing.
this vac advance can go way out there without danger of detonation etc since as soon as you gas for power to accelerate or deal with a load (say up hill) it again snaps straight off due to the spring, because opening the throttle drops the vac up around the ports.
that super advance the vac can delivers results in fuel economy enhancement at cruise.
and......cooler running.
the EPA tests/regs in the very early 70s were strictly concerned with diminishing emissions at idle. ie urban situations, stopped at lights, in traffic at standstill etc.
its in 74 in california and 75 states wide that the EPA went after cruise emissions as well.
ie freeway/interstate driving. hence the vac line from advance can was pulled out of t/bs and tucked under plenums harmlessly and the advance vac port on T/B was plugged or deleted. now you had a situation where the timing was only ever retarded slightly at idle or cruise. bad for fuel economy. engine ran at higher temps around exhaust valve and upper exhaust outlet pipe. but emissions lowered.
only you guys in the states got these double vac cans.
our VWs down here in aus had the simple vac advance cans only from the about mid 60s until the end of the air-cooleds in 76. absolutely no vac retard function in them.
