Full Version: Clutch cable options
jeff
Any recommendations on which cable to purchase? The prices vary quite a bit .
dr914@autoatlanta.com
gemo should be 18.90 dollars. R91442340105
QUOTE(jeff @ Feb 22 2023, 03:55 PM) *
mgphoto
QUOTE(jeff @ Feb 22 2023, 02:55 PM) *
Terry cable, double braided, unlike standard cable which will snap all at once, double braided will snap a few strands at a time giving lots of warning, lasts much longer than standard cable, pricey though.
914Sixer
Beware that the Terry cable maybe TOO long. Not sure if they have corrected that problem. If you go that route compare length BEFORE installation.
sixnotfour
buy a six gemo..
JamesM
QUOTE(914Sixer @ Feb 22 2023, 06:48 PM) *
Terry cables also lack the cable sheath that runs inside the tunnel. Given the potential of the cable rubbing directly on the guide tube every time you step on the clutch along with the near impossibility of completely replacing the clutch tube I went back to using the stock design cables. Gemo, Colfe, OEM Porsche etc.
jeff
Thank you all for the help
