QUOTE(ndfrigi @ Feb 26 2023, 04:12 PM)
that diagram is suspect.
it shows the retard line on the distributor hooked up to where a vac advance port is on the throttle body (sometimes, depending on whether 74 or 75 or calif or 49 states) so it can confuse. the vac retard line from distributor always on all of them goes to the vac retard port on the t/b which faces forward on t/b and is down low. never that one on the back of the t/b which as i say is sometimes there and sometimes not.
there were two different set ups for both 74 and 75 L jets depending on whether california or 49 states.
we did a bit of work on the 74 L jets that sorted those and the vac lines.
we should do one for the 75s that gets them up to date.
haven't had time, but have worked them out.
a 75 L Jet 49 states is basically the same as a 74 californian.
the correct vac diagram for that 74 cal is in originality section of website.
page 3 of thread on the mystery of the L jets.
also the hose hook up for the charcoal can is wrong for engine bay cans.
been back and forths on that for years.
i settled it with recent research.
they changed the can hook ups when they went to engine bay cans.
its all there in the factory literature including date of change.
again its been corrected and proper data is in that topic in originality on page 3.
including the factory literature tracking the change.
been a lot of guessing in the years between 1970s and now leading to bum info.
someone invent a virus program to eat that bum diagram up and purge it from the internet.
