bossboy302
Feb 27 2023, 05:01 PM
Ok, going to begin to knit the wiring together for 2.2 MFI into '72.
Have: '71 911E-
Engine harness
Electrical board
Fuel filter/console
Fuel pump
Have '72 914-
Engine harness
Relay board
I suspect I'll need wiring diagrams for '72 914/'71 911E/ 914-6.
Best current source?
Any directions to such projects also much appreciated. Thanks
r_towle
Feb 27 2023, 05:05 PM
JmuRiz
Feb 27 2023, 09:03 PM
I think Perry Keihl makes custom harnesses…that can eliminate the relay board if needed too.
I’ve been putting off getting one for years, time to order one
B3owulf
Feb 28 2023, 03:07 PM
I am on a similar path, I have a 2.4 MFI engine going in to a '73.
I had seen previous references to Jeff Bowlsby who's site was listed above. I was planning on reaching out when I got a bit further on the project.
Interested to see how your build comes together!
ClayPerrine
Feb 28 2023, 03:25 PM
I had a 2.4L MFI motor in my 914-6 conversion for years. If you need to know how to hook everything up, let me know.
rgalla9146
Mar 1 2023, 09:06 AM
I have a few 3 pin CD harnesses from that era 911s if that would help
targa72e
Mar 1 2023, 10:55 PM
I had a 2.4 MFI engine in my car as well. I was able to move pins around to make the electrical all work. Think I might have added a additional wire for something but do no remember specifics. I found plenty of wiring diagrams online to figure out how to hook up.
FYI, biggest issue I had was no provision for heat thru MFI thermostat with 914-6 exhaust parts (I had headers) and car would not run right. I removed the thermostat and made a manual adjustment for cold start enrichment. Supertec performance has a cable enrichment system for 911's that could be adapted to work with 914.
john
mlindner
Mar 2 2023, 05:37 AM
I went also with a 2.2E in my 74, just had Perry Kieihl build me and engine harness to plug into chaises harness. Relay board deleted, works great.
