QUOTE(peteinjp @ Mar 1 2023, 08:08 AM)
The ground works and I have a bad habit of forgetting the brake is on- definite need the warning lamp!
Here's what I have:
Click to view attachment What switch do I need ab=nd how does it fit?
Best,
Pete
You need the single pole switch that is depressed when the handle is lowered.
The wire pictured actually enters the crossmember through a hole near the floor
and attaches to a female connector on the switch.
If you touch that wire to ground the light should come on.
Your switch has left an impression where it was mounted
