QUOTE(Superhawk996 @ Mar 2 2023, 09:40 AM)
QUOTE(wonkipop @ Mar 1 2023, 10:35 PM)
That rear bar let them soften the rear purely for comfort i believe.
Everyone always assumes stiffer spring rates = better handling but this is not always the case.
Softer rear spring rates in the rear (with bar for roll control) also get you better handling. Especially on a narrow tire with tall sidewall.
Compliance of the wheel vertical travel is a good thing. Too stiff and the tire doesn’t tolerate bumps well, losing grip when it becomes “overloaded” when encountering bumps.
Think of the suspension spring and the tire carcass as two springs in series. In this situation, the softer spring has to be compressed to some degree before the larger spring will even deflect. In an extreme case, the low rate spring will need to go to coil bind or full compression before the larger spring deflects at all. Don’t allow the tire spring rate to be tiny in comparison to the suspension spring rate. No good at all.
@Superhawk996 i always like getting the full story from you.
i've got the lot then. handling to boot with comfort thanks to soft springs/s bar.
it definitely has the softest of the 3 factory springs and thats the way it came.
and i'm riding on tallboy XAS - such soft rubber, its got no grip problems.
probably equal to a 195+ in more conventional everyday compound.
it feels like it driving it.
the only thing that is tweaked is the tyres.
no way were XAS this sticky back in the day.
these current ones are designed to wear out from maybe 10,000 kms of hard use.
i reckon.
anyway its all back to stock and like new with bushings etc done.
set up level.
and it makes you realise how good these cars were straight out of the box.
in 1970!!!!!!
