Full Version: Patch panel needed
bossboy302
I’ve removed 4-cyl motor mount consoles. Rust underneath right side. Is there a repair panel?
bossboy302
That’s a DIY panel.
930cabman
QUOTE(mepstein @ Mar 3 2023, 02:44 PM) *
That’s a DIY panel.
And a tricky one at that
bossboy302
QUOTE(930cabman @ Mar 3 2023, 11:55 AM) *
That’s a DIY panel.
Thank you gentlemen. I'll report back.
Steve
I had the same problem on the passenger side. There was also crack behind it. All we did was drill a hole on each end of the crack and weld it up. We then cut out a scab plate to cover the effected area and used a hole punch similar to other areas and plug welded it on using a MIG welder. After 10 years it still looks fine.
