r_towle
Aug 11 2005, 04:48 PM
I am top cheap to buy the jig that is used for adjusting the shifter Forks.
Does anyone have a pattern for this, or does anyone have one they could loan me, I will make one up from that pattern.
Or, I saw a guy who cut a transmission case to enable
an open view to adjust these shifter forks. I lost that picture....That might be all I need if someone has that picture of the cut away transmission case.
Thanx
Rich
Aaron Cox
Aug 11 2005, 04:50 PM
do a search for Clay Perrine AND shift fork alignment
should be there
AA
ClayPerrine
Aug 11 2005, 05:27 PM
The shift fork jigs are a mandatory thing for adjusting the forks. But I found that even with the jig it can still be misadjusted due to the sheer age of the transmission parts.
By using a transmission that suffered a CV joint impact trauma and opening it up, I was able to adjust the forks on the first try every time.
BTW, anyone want to buy a 901 shift fork adjustment jig?
r_towle
Aug 11 2005, 06:02 PM
Clay, how much for the used Jig???
Or would you loan it out?
Rich
Red-Beard
Aug 11 2005, 09:03 PM
Buy a used transmission. Pick the better one and rebuild it. Cut the case on the reject and make your own tool.
I wish I had the time to do this, as I had something like 8 or 9 cases I tossed out before I left San Diego.
Dominic
Aug 14 2005, 12:25 PM
Here is a picture of the jig I use. This one was given to me, but it looks easy to make if you have a spare case laying around. Plus it's a more accurate way of doing the fork alignment.
Aaron Cox
Aug 14 2005, 01:04 PM
great idea! thx
