Full Version: Air Conditioned Oil Cooler
McMark
I've had a bit of trouble trying to find an answer to this question. I'm hoping maybe ya'll can help.
I'm wonding if any company makes an oil cooler that is Freon/R12/R134/etc to oil cooler instead of an air to oil cooler.
I have a car that will have AC and needs an oil cooler. It seemed smart to run a small portion of the AC refrigerant to cool the oil (no air required). But I can't find any reference of anyone having done this before or anyone selling units.
Crazyhippy
There are lots of companies making water to oil exchangers (boats), but dont know of anyone doing a freon to oil cooler....
Great idea, but a bit of a power rob.
bondo
Cap'n Krusty
Jaguar XJS, XJ6 and XJ12s had A/C cooled fuel. I suppose it could be done with oil. The Cap'n
bondo
The part that seems wacky to me is.. you pump the heat out of the oil, and stick it in front of the radiator.. and for it to work the AC has to be on, which adds an additional load on the engine. Doesn't seem like an efficient way to do things, unless for some reason you had to do it that way, or your oil was only too hot when running the AC.
McMark
With a 3.6 in a 914, I figure the power loss would be barely noticeable. wink.gif
Plus you could only turn on the AC compressor when the oil got hot.
McMark
QUOTE (bondo @ Aug 11 2005, 05:22 PM)
If it's a freon to oil cooler it doesn't need to be in the air stream. wink.gif
bd1308
sorry mark, i just had to post that.....
McMark
QUOTE (bd1308 @ Aug 11 2005, 06:13 PM)
bondo
QUOTE (McMark @ Aug 11 2005, 07:17 PM)
mihai914
Here is a PDF document explaining the functionning of the fuel cooler on a Mercedes similar to what the Cap'n was talking about, I know that this thing gets really cold when refrigerant is running through it.
McMark
I still think it's a damn fine idea on a 3.6. Definitely not a good idea on most engines. I'm just trying to keep the front trunk somewhat useable on this project. wacko.gif I'm still fishing for ideas, so you haven't heard my last question like this. wink.gif
McMark
Thanks Mihai.
bd1308
some people use freon to cool thier computers....
i call them dumb.
mihai914
QUOTE (McMark @ Aug 11 2005, 10:30 PM)
Thanks Mihai.
If only there was one that was a lot larger.  :idea:
You're welcome.
It seems so simple that making one shouldn't be much trouble, something nice out of aluminium and TIG welded...
The hard part would be the fittings in my opinion.
Another idea from Mercedes again, some models have a heater spiral in the windshield washer tank.
You could install a refrigerant cooling coil in your oil tank depending of course of location and the type of tank you will be using, that is probably easier to do.
bondo
QUOTE (McMark @ Aug 11 2005, 07:28 PM)
Yeah, I can see how it would be useful in cetrain applications (like that one). What about the "oil cooler" that sandwiches between the engine and oil filter on some cars? It runs engine coolant through it, and supposedly cools the oil (I'm not sure the delta-T is enough for it to work very well). But if you ran freon through it... I wonder if it could handle the pressure.
I think I still have the one off my LT1 (I took it off because if I need an oil cooler I'll use a "real" one). You can have it if you want something to play with.
mihai914
QUOTE (bd1308 @ Aug 11 2005, 10:32 PM)
i call them dumb.
Yeah but Mark isn't trying to run his motor at a billion gigahertz smile.gif
bd1308
88hp is fine for me...
DJsRepS
I do A/C repair. There are parts called heat exchangers. Has in and out for freon and in and out for another fluid to be heated or cooled by the freon. One of the smaller ones are on the hot water recovery tanks uses hot freon gas to heat some water. If piped after the evap in the car it may super heat the suction so bad that it would take a car's already over worked condenser heat and head pressure bad things could happen. The A/C unit would have to do one task or the other. Cool the car or the oil.
bd1308
why don't people use this at home???
freon, when compressed, gets quite warm....
object is to shed heat.....run some cold water through it....
and you have an increased effeciency in your cooling abilities with freon
and wamer water for the hot water heater...
maf914
QUOTE (bd1308 @ Aug 12 2005, 04:21 AM)
This is becoming more common as people use hydronic cooling for the AC condenser in their homes. A common arrangement is to circulate water through buried tubing which allows you to achieve a 60 degree (typical ground temperature) water source heat sink. This is more efficient than 100 degree air in the summer or 32 degree air in the winter (in heat pump mode). Besides the increased efficiency you also replace the noisy condenser fan with a quiet water pump. The downside is the first cost of burying a bunch of plastic tubing in your yard. I hope to do a systen like this in the future.
bd1308
i was going with another approach....
but geo-thermal climate control is a neat thing....
very expensive now, but soon will come down.
supply and demand..
SpecialK
DJsRepS is correct on the pressure increase from the added load being a Baaaad thing, automotive A/C's weren't designed for that. Plus, the added heat would definitely effect the operation of the high/low pressure switches in the system.
Neat concept tho.....Hey, how about mounting a residential window unit in your front trunk, and using a power inverter to run it!! wink.gif biggrin.gif
SpecialK
QUOTE (bd1308 @ Aug 12 2005, 10:31 AM)
supply and demand..
I assisted in the installation of a couple of geo-thermal heat pumps. Wasn't so much the cost of the equipment, but the labor involved that jacked the price up.
Demick
Mark
This sounds kind of like someone opening their freezer door to try and cool off their house - the end result is that the opposite happens.
The only real way to get rid of heat on a car is to eventually dump it out to the air. You have oil that you need to dump some heat out of. But rather than going straight to the air, you are suggesting transferring that heat to an A/C system. When you do that, the AC system now needs to get rid of that same amount of heat. Only the AC system takes work to do that. Where does that work come from? The engine. So the engine now needs to produce more power to run the AC system. Doing this work generates even more heat that will need to be gotten rid of as well. Where is all this heat going to go? Eventually, into the airstream as well - so now you've got to size your AC condensor (which is really just a radiator) to get rid of all that heat.
Here are some example numbers.
Say you want to dump 20,000 watts of heat from the oil.
So you transfer it from the oil to the freon.
The Freon now has an extra 20KW of heat to get rid of.
Due to efficiency of an AC system, it will take about 8KW of power to get rid of the 20KW of heat.
So the engine now needs to make an additional 8KW of power.
But the engine will create about 8KW more heat in generating this extra power (24KW of fuel --> 8KW goes to power, 8KW of heat goes out tailpipe, 8KW of heat goes to cooling system)
So now your oil has an extra 8KW of heat in it because you tried to us an AC system to get rid of 20KW of heat.
Anyway, you see my reasoning here. Bottom line is, you need to get the heat out to the air, and a radiator of some sort is the only real way to do that. So either way, you've got to have enough volume of air flowing through a large enough radiator - whether that radiator is an oil-to-air, water-to-air, or freon-to-air style, or any combination of the above. But going straight from oil-to-air will by far be the most efficient.
The laws of thermodymanics are at work here. The only part of it that you have a say in is the efficiency of the system. There's no magical way to get rid of the heat - it has to go somewhere.
Demick
messix
ford lighting trucks used a airconditioning powered intercooler between the supercharger and the intake that only was active during full throttle.
just some thing of related but useless info
zymurgist
My W126 (Mercedes-Benz 420SEL) has a fuel cooler.
It also routes engine coolant through the windshield washer reservoir so the washer fluid doesn't freeze.
Those German engineers think of everything.
messix
you mean over engineer everthing
zymurgist
QUOTE (messix @ Aug 12 2005, 01:10 PM)
I can see why you might say that. However, having worked on the car extensively last year in a successful effort to turn it into my backup daily driver/weekend cruiser, I had nothing but admiration for the Mercedes engineers' attention to detail. Rack and pinion system to tension V-belts, flare fittings where the AT lines connect to the radiator (no hose clamps there!)... the way the car was put together shows that they thought about how it was to be serviced (rather than merely how it was to be assembled at the factory), and to me that indicates that they intended for the vehicle to be in service for many, many years.
And speaking of vehicles that have been in service for many years, the newest 914's are approaching 30 years old.
bd1308
with the exception of the battery rot, the 914 IMHO was done the very same way.
some things they couldn't help--ie the pot metal door handles and the $$$$$$$ hand grenade...
bondo
I agree with what Demick said, but there could be some advantages. There is inefficiency in extra steps of heat transfer, but the if the AC system raises the delta-T enough, it could work. Say the oil is at 250 degrees, and the freon is at 30 degrees.. the transfer of heat to the freon is going to be very effective, because of the huge temp difference. Now if the compressed freon goes to like 300 degrees to shed the heat, it can do it with less radiating space than an oil cooler at 250 degrees. I don't know if that's the way it would happen, but if it did, it might be enough to make up for the added load and related added heat. I don't know anything about the raised system pressures, but that can't be a good thing.
zymurgist
And also with the exception of the non-galvanized sheet metal that the body was made from? Well, personally I wouldn't blame Porsche for that. I mean, look at other unibody cars of the same vintage and see how they have fared for rust.
Datsun 240Z? Rust.
British roadsters? Rust.
Porsche 911? You guessed it, rust.
Corvettes have held up better over the years because they use a body-on-frame construction. If the frame rusts, you can replace it (although most people just part out the car at that point).
Mueller
QUOTE (bd1308 @ Aug 12 2005, 11:28 AM)
huh??
what part of the car would that be??
Mark,
Since the motor is a nice big /6, you could possibly use "bleed" air from the fan to help cool the oil-cooler.
On my 3.6 in the 911, there is a hose installed in between the fan housing and the distributor to help get rid of the ozone gas that attacked the rubber belt.
bd1308
no imagination......
Mueller
QUOTE (bd1308 @ Aug 12 2005, 11:44 AM)
considering there are still good MPS's being used 30 years after being first manufactured, that is pretty darn good engineering in my book....
SpecialK
Okay, how about using a small secondary evaporator coil (downstream of the pass. comp. evap coil) to cool the air blowing across a standard air-to-air oil cooler. No huge load on the compressor, and would only pre-cool the air (all important Delta T) when the outside temps are high enough to justify running the A/C. confused24.gif
The ducting wouldn't have to be all that elaborate, and a blower wouldn't really even be need if the inlet was in the air stream.
bd1308
yeah but who makes beryllium diaphragms nowadays?
nobody.
imagine ten years down the road when the steel ones are all that are left.......
bd1308
nobody.
i agree it was a good engineering idea.....
just weren't made to last....
look at how many there were, compared to how many there are now.
Jake Raby
All I know is that an oil cooler with a block of dry ice strapped to it with a zip tie works very well....
Don't ask how or when I tried this!!!!
Mueller
QUOTE (bd1308 @ Aug 12 2005, 11:54 AM)
nobody.
how many you want??
You can have them made all day long.............the problem is no-one wants to put up the money to do the R&D and have the first batch of them made.....it's been looked into, figure about $5,000 would be needed in order to have the first run of parts made.......
there is no shortage of beryllium-copper.........
Mueller
QUOTE (bd1308 @ Aug 12 2005, 11:55 AM)
no car is "designed" to last forever, it wasn't until 20 years ago that the manufactures decided that it's good practice to make the cars last a "little" longer than previously........if made bullet proof, the market for new cars would get stale
bd1308
i realize that....
actually i dont think the new car market would get stale if cars lasted forever......
people always want bigger, better and newer.
I didn't say there was a shortage of the elements, I did say that there are no more pre-made diaphragms left.
$5,000 is a lot of money for little diaphragms.....what I'm saying is that I am personally worried about how long I will still be able to buy 1.7 P&C kits or cams for my type4.....
ArtechnikA
QUOTE (bd1308 @ Aug 12 2005, 03:09 PM)
you can get just about any piston you want from JE in a matter of weeks; they have mastered the art of short-run custom near-net aluminum forging. Nickies are custom made. cams are ground fresh from billet.
there were hundreds of thousands of 1,7-liter engines made.
there are guys still running and building engines for 356's made 50 years ago - that were originally made in quantities of tens to hundreds.
a properly built 1,7 should go 200,000 mi on pistons and a cam. that's 10,000 mi a year for 20 years. i'm more worried about finding gasoline than pistons in 2025...
