bobforman
Mar 20 2023, 04:38 PM
Thinking I had drawn a diagram of all the wires before pulling the transmission, I seem to have neglected the large black ground wire which is now resting on top of the trans. Where does this one attach?
GregAmy
Mar 20 2023, 06:02 PM
There should be a 6mm (or is it 8mm?) stud extending from the bottom side of the trunk floor, toward the mid/aft end of the transaxle.
If not, anywhere on the chassis will do.
EDIT: BTW, while any good wire will do, the stock one was a braided steel strap.
bobforman
Mar 20 2023, 06:58 PM
Thanks, Greg. I've got the braided ground wire hooked up. This one is a round, battery-like cable coming from above the passenger side. I'll have to trace it to its origin and figure out more from that.
technicalninja
Mar 20 2023, 07:11 PM
The only large cable on my 75 coming from the passenger side is the power supply lead for the starter.
It is black...
But it is not a ground.
What do you have hooked to the large terminal on your starter?
bobforman
Mar 21 2023, 12:23 AM
Thanks, tech. That's got to be the answer.
