QUOTE(rgalla9146 @ Apr 1 2023, 10:02 AM)
QUOTE(BillJ @ Mar 31 2023, 02:46 PM)
Anyone here have one they want to part with? Want to build a second transmission for the racecar.
Clarification: need it to also be side shift.
Bonus if limited slip. That would be my ideal.
I think you're looking for a 911 trans from '70-'71, not a 901 (911 300 000 00) It's the first version with the pull type clutch.
As you probably know a 914 trans can be converted, I have the correct throw out arm.
My brother has a 911 type for sale but it's here in NJ
I sold one to Joe Cogbill of CogsCogs a couple years ago, he's from Georgia
Call me if you like, I pm'd you
The 70-71` 911 transmission that used the pull type clutch was different in the bellhousing area. The pivot point for the throwout arm is in a different location than the 914 trans, and it is reenforced with a steel "top hat" insert to prevent pulling out the threads.
Converting a 914 trans is NOT recommended. It will pull the threads out of the case in short order.
Also, the throwout bearing and pressure plate are unique to the 70-71 911. You can put in the later pressure plates, but they have too much pressure for the 70-71 911 clutch setup. And the throwout bearing is completely different from the later ones.
I know all this because I have a 71 911 trans that is converted to a side shift 914 trans, re-geared for the 2.4 S motor it is hooked to, sitting on the floor of the garage. I have a plan for the whole drive train, but it has not come to fruition yet.
