2.8L long block
Serial number 6362056
10.8:1 compression ratio
92mm Mahle PC's
RSR Sprint cams with MFI drive
Twin-plug ported heads
36mm intake / 35mm exhaust
7R case, line-bored 1st oversize
Carrera oil pump
Carrera chain tensioners
964 lower valve covers
Built in 1990 by Larry's Performance Works in Ashville, NC
Receipts show 2 rebuilds for a total of $19500
1st to RS specs, then 2 months later to RSR specs
260hp @7000 195lb/ft per dyno sheet
Recently removed from 914-6 race car to address typical oil leaks
Leak-down tested cold before removal <4% on all 6 cylinders
Asking $12,500 or best offer
Pics here:
https://drive.google.com/drive/folders/1E83...?usp=share_link
