914beginner
Jul 26 2003, 01:20 PM
Hello anyone????
Could someone give me some help with an ignition problem? I have recently rebuilt the motor on my 74 with carb conversion and am having problems getting fire. I have a total of 6 wires at the coil. 1 coil wire, 1 red, 1 green, 1 beige, and 1 green to the post on the distributor. I don't even know for sure if I have these hooked up right...could someone confirm? I have had fire at the points, but the green wire to the post on the distributor begins to smoke after tuning on the ingition switch. I have dash gauges and fuel pump. Any ideas?
Thanks...beginner
garyh
Jul 26 2003, 02:35 PM
6 wires at the coil? And -all- of them the wrong color? Whoa boy, does you have problems.
Green wire goes from the coil to the dizzy.
Black/Red wire (what black wire, he asks) comes from the ignition to the coil.
Black/Purple wire goes from coil to tach.
Bill Saderwhite (???) sells color wiring diagrams for cheap. Get one.
tryan
Jul 26 2003, 03:04 PM
the hot wire goes to the '+' terminal on the coil. the green and black/purple/tach wire goes to the negative post.
whatcha smokin'. i would say you burnt the points together. you might want to check that. pelican has the teener wiring diagrams.
welcome to the group w bench.
TheCabinetmaker
Jul 26 2003, 06:31 PM
green wire from condenser will smoke if hooked to the positive terminal on the coil. It goes on the negative side.
914beginner
Jul 27 2003, 09:04 PM
Hi guys,
Thanks for the advice. One side of the points was shorting out causing resistence in the wire and I figured out the other wires. Now if I can only get the thing timed so it will run.
Jeffs9146
Jul 27 2003, 09:13 PM
Check to make sure the dist. is not 180' off!? TDC to the proper cylinder?
Jeff
